Ir para o conteúdo principal
General Electric Create Jason Wu Power Supply Button Replacement
O que você precisa
    1. General Electric Create Jason Wu Power Supply Button Replacement, General Electric Create Jason Wu Casing Disassembly: passo 1, imagem 1 %32 General Electric Create Jason Wu Power Supply Button Replacement, General Electric Create Jason Wu Casing Disassembly: passo 1, imagem 2 %32 General Electric Create Jason Wu Power Supply Button Replacement, General Electric Create Jason Wu Casing Disassembly: passo 1, imagem 3 %32
      • Begin by removing the 5 screws (located: 2 screws on either side and 1 screw on the bottom) using the PH000 head in the Precision Phillips Screwdriver.
      • These screws were missing in our example. These screws should have been small Phillips PH000 screws 1.5mm in length.
      • These screws are very small. To keep from losing any pieces, place all small metals on a magnetic project mat.
      Pergunte ao FixBot
      Comentar
    2. General Electric Create Jason Wu Power Supply Button Replacement: passo 2, imagem 1 %32 General Electric Create Jason Wu Power Supply Button Replacement: passo 2, imagem 2 %32
      • After the screws are removed, pull the front casing up and away from the camera.
      • If the casing is difficult to remove, use a plastic opening tool to gently pry up on the front as shown.
      Pergunte ao FixBot
      Comentar
    3. General Electric Create Jason Wu Power Supply Button Replacement: passo 3, imagem 1 %32 General Electric Create Jason Wu Power Supply Button Replacement: passo 3, imagem 2 %32 General Electric Create Jason Wu Power Supply Button Replacement: passo 3, imagem 3 %32
      • Using your hands or an opening tool, pry off the silver frame, taking special care at the top of the camera where the buttons are as it is a little harder to pry off.
      • If the back casing is loose from the camera body, it may be easier to perform step 4 first, then accomplish this step. Proceed as your unit allows.
      Pergunte ao FixBot
      Comentar
    4. General Electric Create Jason Wu Power Supply Button Replacement: passo 4, imagem 1 %32 General Electric Create Jason Wu Power Supply Button Replacement: passo 4, imagem 2 %32 General Electric Create Jason Wu Power Supply Button Replacement: passo 4, imagem 3 %32
      • The last part of the casing to disconnect is the back that houses the LCD screen.
      • The screen is attached by a connection ribbon. Gently pull the casing and screen away from the camera body to disconnect the casing.
      • The LCD screen is held onto the back casing by a small amount of adhesive. This may come loose during this process. Do not worry if they become separated.
      • This plug and the connection ribbon are fragile, try not to tear the connection ribbon when disconnecting.
      Pergunte ao FixBot
      Comentar
    1. General Electric Create Jason Wu Power Supply Button Replacement, Power Supply Button: passo 5, imagem 1 %32 General Electric Create Jason Wu Power Supply Button Replacement, Power Supply Button: passo 5, imagem 2 %32 General Electric Create Jason Wu Power Supply Button Replacement, Power Supply Button: passo 5, imagem 3 %32
      Ferramenta utilizada neste passo:
      Flathead 3/32" or 2.5 mm Screwdriver
      $5.49
      • Locate the metal frame removed from around the camera in step 3.
      • Lay the frame button side down or flat and gently pry the button out of place with the 3.0 flathead bit or a pair of tweezers.
      • This is very brittle plastic so use extreme caution and minimal force.
      • The button is secured to the frame by two small black rods pushed into the white colored portion of the button (see picture).
      Pergunte ao FixBot
      Comentar
    2. General Electric Create Jason Wu Power Supply Button Replacement: passo 6, imagem 1 %32
      • The button will pry off easily and shouldn't take much force
      Pergunte ao FixBot
      Comentar
Conclusão
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 28
Ao todo: 588
