Ir para o conteúdo principal
General Electric Create Jason Wu Casing Disassembly
O que você precisa
    1. General Electric Create Jason Wu Casing Disassembly, General Electric Create Jason Wu Casing Disassembly: passo 1, imagem 1 %32 General Electric Create Jason Wu Casing Disassembly, General Electric Create Jason Wu Casing Disassembly: passo 1, imagem 2 %32 General Electric Create Jason Wu Casing Disassembly, General Electric Create Jason Wu Casing Disassembly: passo 1, imagem 3 %32
      • Begin by removing the 5 screws (located: 2 screws on either side and 1 screw on the bottom) using the PH000 head in the Precision Phillips Screwdriver.
      • These screws were missing in our example. These screws should have been small Phillips PH000 screws 1.5mm in length.
      • These screws are very small. To keep from losing any pieces, place all small metals on a magnetic project mat.
      Pergunte ao FixBot
      Comentar
    2. General Electric Create Jason Wu Casing Disassembly: passo 2, imagem 1 %32 General Electric Create Jason Wu Casing Disassembly: passo 2, imagem 2 %32
      • After the screws are removed, pull the front casing up and away from the camera.
      • If the casing is difficult to remove, use a plastic opening tool to gently pry up on the front as shown.
      Pergunte ao FixBot
      Comentar
    3. General Electric Create Jason Wu Casing Disassembly: passo 3, imagem 1 %32 General Electric Create Jason Wu Casing Disassembly: passo 3, imagem 2 %32 General Electric Create Jason Wu Casing Disassembly: passo 3, imagem 3 %32
      • Using your hands or an opening tool, pry off the silver frame, taking special care at the top of the camera where the buttons are as it is a little harder to pry off.
      • If the back casing is loose from the camera body, it may be easier to perform step 4 first, then accomplish this step. Proceed as your unit allows.
      Pergunte ao FixBot
      Comentar
    4. General Electric Create Jason Wu Casing Disassembly: passo 4, imagem 1 %32 General Electric Create Jason Wu Casing Disassembly: passo 4, imagem 2 %32 General Electric Create Jason Wu Casing Disassembly: passo 4, imagem 3 %32
      • The last part of the casing to disconnect is the back that houses the LCD screen.
      • The screen is attached by a connection ribbon. Gently pull the casing and screen away from the camera body to disconnect the casing.
      • The LCD screen is held onto the back casing by a small amount of adhesive. This may come loose during this process. Do not worry if they become separated.
      • This plug and the connection ribbon are fragile, try not to tear the connection ribbon when disconnecting.
      Pergunte ao FixBot
      Comentar
Conclusão
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 21
Ao todo: 580
