Ir para o conteúdo principal
Gateway W350I Display Replacement
O que você precisa
    1. Gateway W350I Display Replacement, Battery Access: passo 1, imagem 1 %32
      • Turn the laptop upside down and position it as shown in the image.
      Pergunte ao FixBot
      Comentar
    2. Gateway W350I Display Replacement, Unlocking the Battery: passo 2, imagem 1 %32 Gateway W350I Display Replacement, Unlocking the Battery: passo 2, imagem 2 %32 Gateway W350I Display Replacement, Unlocking the Battery: passo 2, imagem 3 %32
      • Slide the locking switch towards the open lock picture.
      • Hold the release switch in the unlocked position while simultaneously pushing the battery away from the laptop.
      • Once the laptop is disengaged, completely remove the battery from the laptop.
      Pergunte ao FixBot
      Comentar
    1. Gateway W350I Display Replacement, Remove Rubber Protectors & Screws: passo 3, imagem 1 %32 Gateway W350I Display Replacement, Remove Rubber Protectors & Screws: passo 3, imagem 2 %32
      • Pry the six black rubber protectors out of the screw holes.
      • Remove all six of the 4mm Phillips #0 screws that were covered by the rubber protectors.
      Pergunte ao FixBot
      Comentar
    2. Gateway W350I Display Replacement, Separate Plastic Casing: passo 4, imagem 1 %32 Gateway W350I Display Replacement, Separate Plastic Casing: passo 4, imagem 2 %32
      • Separate the plastic screen casing from the laptop lid by inserting a plastic opening tool. Complete this step around the top and along both sides of the screen.
      Pergunte ao FixBot
      Comentar
    3. Gateway W350I Display Replacement, Remove Bracket from Laptop Lid: passo 5, imagem 1 %32 Gateway W350I Display Replacement, Remove Bracket from Laptop Lid: passo 5, imagem 2 %32
      • Remove the two 4mm Phillips #0 screws located at the top that fasten the screen bracket to the laptop.
      Pergunte ao FixBot
      Comentar
    4. Gateway W350I Display Replacement, Remove LCD Screen from Bracket: passo 6, imagem 1 %32
      • Separate the bracket and the screen from its original position within the lid of the laptop.
      • Remove the four 4mm Phillips #0 screws on the sides of the bracket that hold the LCD screen.
      Pergunte ao FixBot
      Comentar
    5. Gateway W350I Display Replacement, Remove Video Cable: passo 7, imagem 1 %32 Gateway W350I Display Replacement, Remove Video Cable: passo 7, imagem 2 %32
      • Detach the video cable that is attached to the laptop from the back of the screen.
      • Be careful while removing the video cable as it is very delicate.
      Pergunte ao FixBot
      Comentar
    6. Gateway W350I Display Replacement: passo 8, imagem 1 %32 Gateway W350I Display Replacement: passo 8, imagem 2 %32
      • Disconnect the camera connector from the circuit board to completely free the screen.
      Pergunte ao FixBot
      Comentar
Conclusão
3 outras pessoas executaram este guia.
Equipe
USF Tampa, Team 4-1, Brown Fall 2014 Membro de USF Tampa, Team 4-1, Brown Fall 2014
USFT-BROWN-F14S4G1
3 Membros
Autoria de 30 guias
1Comentário do guia
It was very easy to follow.
Very friendly guide.
stewilli - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 6
Últimos 30 dias: 35
Ao todo: 1,762
