Introdução
Follow this replacement guide to replace or upgrade your RAM stick.
Adding memory is one of the easiest ways to boost your Gateway Solo 1200’s performance. To find how much RAM your computer has, go to the device specifications in your PC’s settings. This will not only tell you how much RAM your computer has but also how much RAM it can support for possible upgrades.
O que você precisa
Locate the battery latch on the bottom of the laptop.
Release the latch by pressing it with your thumb and sliding it to the right.
Slide the battery out of its compartment.
5 outras pessoas executaram este guia.
