Ir para o conteúdo principal
Gateway SA1 Screen Replacement
O que você precisa
    1. Gateway SA1 Screen Replacement, Battery: passo 1, imagem 1 %32
      • Move the latch to the right of the battery to unlock.
      Pergunte ao FixBot
      Comentar
    2. Gateway SA1 Screen Replacement: passo 2, imagem 1 %32
      • Slide the latch on the left directly below the battery to unlock and pull out the battery as shown.
      • The latch must be held in position to remove the battery.
      Pergunte ao FixBot
      Comentar
    1. Gateway SA1 Screen Replacement, Screen: passo 3, imagem 1 %32 Gateway SA1 Screen Replacement, Screen: passo 3, imagem 2 %32
      • Remove the hinge covers by lifting each with the sharp point of the spudger.
      • Notice that the middle cover has a different shape and is more difficult to remove.
      Pergunte ao FixBot
      Comentar
    2. Gateway SA1 Screen Replacement: passo 4, imagem 1 %32 Gateway SA1 Screen Replacement: passo 4, imagem 2 %32
      • Remove the six screw covers on the front bezel with the sharp point of the spudger.
      • The bottom two are more difficult to remove.
      Pergunte ao FixBot
      Comentar
    3. Gateway SA1 Screen Replacement: passo 5, imagem 1 %32
      • Remove the six 5.9 mm Philips screws securing the screen bezel.
      Pergunte ao FixBot
      Comentar
    4. Gateway SA1 Screen Replacement: passo 6, imagem 1 %32 Gateway SA1 Screen Replacement: passo 6, imagem 2 %32 Gateway SA1 Screen Replacement: passo 6, imagem 3 %32
      • Remove the front bezel by prying it off with the wedged end of the spudger.
      • Verify that your spudger does not touch the LCD.
      • The screen inverter is now exposed below the LCD.
      Pergunte ao FixBot
      Comentar
    5. Gateway SA1 Screen Replacement: passo 7, imagem 1 %32
      • Remove the single 3.8mm Phillips screw mounting the screen inverter to the computer.
      Pergunte ao FixBot
      Comentar
    6. Gateway SA1 Screen Replacement: passo 8, imagem 1 %32 Gateway SA1 Screen Replacement: passo 8, imagem 2 %32
      • Use your finger, or the spudger, to pry the inverter board out.
      • This exposes the wires behind it.
      Pergunte ao FixBot
      Comentar
    7. Gateway SA1 Screen Replacement: passo 9, imagem 1 %32
      • Unplug the LCD back light cables from the right side of the screen inverter.
      Pergunte ao FixBot
      Comentar
    8. Gateway SA1 Screen Replacement: passo 10, imagem 1 %32 Gateway SA1 Screen Replacement: passo 10, imagem 2 %32
      • Remove the six screws that mount the screen to the hinge mounts.
      • Two 2.5 mm Phillips screws.
      • Four 3.8 mm Phillips screws.
      Pergunte ao FixBot
      Comentar
    9. Gateway SA1 Screen Replacement: passo 11, imagem 1 %32
      • Unplug the cable from the webcam board.
      • Be gentle, do not use excessive force or you may break the connection.
      Pergunte ao FixBot
      Comentar
    10. Gateway SA1 Screen Replacement: passo 12, imagem 1 %32
      • Separate the screen from the display cover.
      • Do not touch the back of the screen.
      Pergunte ao FixBot
      Comentar
    11. Gateway SA1 Screen Replacement: passo 13, imagem 1 %32 Gateway SA1 Screen Replacement: passo 13, imagem 2 %32
      • Remove the three tape strips that hold down the cables.
      • Be careful not to tear any of the tape. The piece holding down the webcam wires is especially delicate.
      Pergunte ao FixBot
      Comentar
    12. Gateway SA1 Screen Replacement: passo 14, imagem 1 %32 Gateway SA1 Screen Replacement: passo 14, imagem 2 %32
      • Unplug the display data cable from the screen connector.
      • This connection is very fragile; do not use excessive force.
      • The screen should now be free from all wire connections.
      Pergunte ao FixBot
      Comentar
    13. Gateway SA1 Screen Replacement: passo 15, imagem 1 %32
      • Remove the four 2.8 mm Phillips screws that secure the screen to the mounting bracket using a screwdriver.
      • There will be two screws on either side of the mounting bracket.
      Pergunte ao FixBot
      Comentar
    14. Gateway SA1 Screen Replacement: passo 16, imagem 1 %32
      • You can now remove and replace the screen.
      Pergunte ao FixBot
      Comentar
Conclusão
Equipe
Cal Poly, Team 24-20, Regan Spring 2010 Membro de Cal Poly, Team 24-20, Regan Spring 2010
CPSU-REGAN-S10S24G20
4 Membros
Autoria de 70 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 13
Últimos 30 dias: 44
Ao todo: 19,486
