Ir para o conteúdo principal
Gateway SA1 RAM Replacement
O que você precisa
    1. Gateway SA1 RAM Replacement, Battery: passo 1, imagem 1 %32
      • Move the latch to the right of the battery to unlock.
      Pergunte ao FixBot
      Comentar
    2. Gateway SA1 RAM Replacement: passo 2, imagem 1 %32
      • Slide the latch on the left directly below the battery to unlock and pull out the battery as shown.
      • The latch must be held in position to remove the battery.
      Pergunte ao FixBot
      Comentar
    1. Gateway SA1 RAM Replacement, RAM: passo 3, imagem 1 %32 Gateway SA1 RAM Replacement, RAM: passo 3, imagem 2 %32
      • Loosen the indicated Philips screw that connects the memory bay cover to the casing.
      • The indicated Philips screw does not come out of the cover.
      Pergunte ao FixBot
      Comentar
    2. Gateway SA1 RAM Replacement: passo 4, imagem 1 %32 Gateway SA1 RAM Replacement: passo 4, imagem 2 %32
      • Lift and remove the cover using the spudger.
      Pergunte ao FixBot
      Comentar
    3. Gateway SA1 RAM Replacement: passo 5, imagem 1 %32 Gateway SA1 RAM Replacement: passo 5, imagem 2 %32
      • Gently press the clip outwards.
      • The module will tilt up and can be pulled out of the slot.
      • There may be another memory module underneath so be sure to remove both.
      Pergunte ao FixBot
      Comentar
    4. Gateway SA1 RAM Replacement: passo 6, imagem 1 %32
      • To insert a new memory, slide the module into the slot at a 30 to 45 degree angle.
      • Place the first module into the bottom slot then the next module into the top slot.
      • These slots are keyed so verify that you are sliding the module in one direction.
      • Verify that the new memory modules are designed for your specific Gateway Laptop.
      Pergunte ao FixBot
      Comentar
Conclusão
3 outras pessoas executaram este guia.
Equipe
Cal Poly, Team 24-20, Regan Spring 2010 Membro de Cal Poly, Team 24-20, Regan Spring 2010
CPSU-REGAN-S10S24G20
4 Membros
Autoria de 42 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 38
Ao todo: 6,094
