Ir para o conteúdo principal
Gateway SA1 Outer Casing Replacement
O que você precisa
    1. Gateway SA1 Outer Casing Replacement, Battery: passo 1, imagem 1 %32
      • Move the latch to the right of the battery to unlock.
      Pergunte ao FixBot
      Comentar
    2. Gateway SA1 Outer Casing Replacement: passo 2, imagem 1 %32
      • Slide the latch on the left directly below the battery to unlock and pull out the battery as shown.
      • The latch must be held in position to remove the battery.
      Pergunte ao FixBot
      Comentar
    1. Gateway SA1 Outer Casing Replacement, Disk Drive: passo 3, imagem 1 %32
      • Unscrew the marked 5.9 mm Philips screw.
      Pergunte ao FixBot
      Comentar
    2. Gateway SA1 Outer Casing Replacement: passo 4, imagem 1 %32
      • Use the spudger to pry out the Disk dive.
      Pergunte ao FixBot
      Comentar
    3. Gateway SA1 Outer Casing Replacement: passo 5, imagem 1 %32
      • The disk drive should easily detach and can now be replaced.
      Pergunte ao FixBot
      Comentar
    1. Gateway SA1 Outer Casing Replacement, Outer Casing: passo 6, imagem 1 %32
      • Remove the twelve 5.9 mm Philips screws from the back cover.
      • Remove one 8.8 mm Philips screw from the back cover.
      Pergunte ao FixBot
      Comentar
    2. Gateway SA1 Outer Casing Replacement: passo 7, imagem 1 %32 Gateway SA1 Outer Casing Replacement: passo 7, imagem 2 %32 Gateway SA1 Outer Casing Replacement: passo 7, imagem 3 %32
      • Unscrew the two 5.9 mm Philips screws located on the the side closest to the battery.
      • Unscrew the three 3.6 mm Philips screws that are within the Disk drive port.
      Pergunte ao FixBot
      Comentar
    3. Gateway SA1 Outer Casing Replacement: passo 8, imagem 1 %32 Gateway SA1 Outer Casing Replacement: passo 8, imagem 2 %32
      • Remove the hinge covers by lifting each with the sharp point of the spudger.
      • Notice that the middle cover has a different shape and is more difficult to remove.
      Pergunte ao FixBot
      Comentar
    4. Gateway SA1 Outer Casing Replacement: passo 9, imagem 1 %32 Gateway SA1 Outer Casing Replacement: passo 9, imagem 2 %32 Gateway SA1 Outer Casing Replacement: passo 9, imagem 3 %32
      • There will be a connection underneath the speaker cover.
      • Remove the speaker cover using the spudger.
      Pergunte ao FixBot
      Comentar
    5. Gateway SA1 Outer Casing Replacement: passo 10, imagem 1 %32
      • Unscrew the two 3.9 mm Philips screws and remove the keyboard.
      Pergunte ao FixBot
      Comentar
    6. Gateway SA1 Outer Casing Replacement: passo 11, imagem 1 %32 Gateway SA1 Outer Casing Replacement: passo 11, imagem 2 %32 Gateway SA1 Outer Casing Replacement: passo 11, imagem 3 %32
      • Carefully lift the keyboard off from the laptop. It is still attached as shown.
      • Using the spudger, detach the connector by pushing two tabs away from the white connector and then gently pulling the connector away.
      • The brown colored component with the tabs does not come out with the connector.
      Pergunte ao FixBot
      Comentar
    7. Gateway SA1 Outer Casing Replacement: passo 12, imagem 1 %32 Gateway SA1 Outer Casing Replacement: passo 12, imagem 2 %32 Gateway SA1 Outer Casing Replacement: passo 12, imagem 3 %32
      • Lift up the black tab and gently pull out the connector.
      Pergunte ao FixBot
      Comentar
    8. Gateway SA1 Outer Casing Replacement: passo 13, imagem 1 %32 Gateway SA1 Outer Casing Replacement: passo 13, imagem 2 %32
      • Unscrew the four marked 5.9 mm Philips screws.
      Pergunte ao FixBot
      Comentar
    9. Gateway SA1 Outer Casing Replacement: passo 14, imagem 1 %32 Gateway SA1 Outer Casing Replacement: passo 14, imagem 2 %32
      • Move the wires out of the fixed space as shown.
      Pergunte ao FixBot
      Comentar
    10. Gateway SA1 Outer Casing Replacement: passo 15, imagem 1 %32 Gateway SA1 Outer Casing Replacement: passo 15, imagem 2 %32
      • Unscrew the five marked 3.8 mm Philips screws.
      • Three screws are located on the right side of the screen.
      • Two screws are located on the left side of the screen.
      Pergunte ao FixBot
      Comentar
    11. Gateway SA1 Outer Casing Replacement: passo 16, imagem 1 %32
      • Remove the screen brackets from the computer's base.
      Pergunte ao FixBot
      Comentar
    12. Gateway SA1 Outer Casing Replacement: passo 17, imagem 1 %32 Gateway SA1 Outer Casing Replacement: passo 17, imagem 2 %32 Gateway SA1 Outer Casing Replacement: passo 17, imagem 3 %32
      • Remove the four 5.9 mm Philips screws as indicated:
      • There is one somewhat hidden screw on the left side under the screen hinge, and one to the right of the (left)speaker, right/top side of the video port on mobo.
      • There are two similarly positioned screws on the right side.
      Pergunte ao FixBot
      Comentar
    13. Gateway SA1 Outer Casing Replacement: passo 18, imagem 1 %32 Gateway SA1 Outer Casing Replacement: passo 18, imagem 2 %32
      • The following steps (18 - 20) explain how to remove the three indicated connections.
      • The order is Blue, Violet, Orange.
      • Lift the white tab up and gently take out the connector.
      Pergunte ao FixBot
      Comentar
    14. Gateway SA1 Outer Casing Replacement: passo 19, imagem 1 %32
      • Use the spudger to pull off the black attachment.
      Pergunte ao FixBot
      Comentar
    15. Gateway SA1 Outer Casing Replacement: passo 20, imagem 1 %32
      • Lift and pull the black tab upward until it becomes unattached.
      • Some force may be required.
      Pergunte ao FixBot
      Comentar
    16. Gateway SA1 Outer Casing Replacement: passo 21, imagem 1 %32
      • Use the spudger to remove the casing as seen in the picture.
      Pergunte ao FixBot
      Comentar
    17. Gateway SA1 Outer Casing Replacement: passo 22, imagem 1 %32
      • Remove the casing.
      Pergunte ao FixBot
      Comentar
Conclusão
6 outras pessoas executaram este guia.
Equipe
Cal Poly, Team 24-20, Regan Spring 2010 Membro de Cal Poly, Team 24-20, Regan Spring 2010
CPSU-REGAN-S10S24G20
4 Membros
Autoria de 42 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 10
Últimos 30 dias: 45
Ao todo: 16,510
