Ir para o conteúdo principal
Gateway SA1 Hard Drive Replacement
O que você precisa
    1. Gateway SA1 Hard Drive Replacement, Battery: passo 1, imagem 1 %32
      • Move the latch to the right of the battery to unlock.
      Pergunte ao FixBot
      Comentar
    2. Gateway SA1 Hard Drive Replacement: passo 2, imagem 1 %32
      • Slide the latch on the left directly below the battery to unlock and pull out the battery as shown.
      • The latch must be held in position to remove the battery.
      Pergunte ao FixBot
      Comentar
    1. Gateway SA1 Hard Drive Replacement, Hard Drive: passo 3, imagem 1 %32
      • Before you begin, it's recommended that you back up all your computer's information on the original hard drive. Also, verify the laptop is off and all cables are disconnected.
      • Turn the laptop over so the bottom is facing up.
      Pergunte ao FixBot
      Comentar
    2. Gateway SA1 Hard Drive Replacement: passo 4, imagem 1 %32 Gateway SA1 Hard Drive Replacement: passo 4, imagem 2 %32
      • Loosen the three Philips cover screws that secure the hard drive.
      • These screws cannot be fully removed from the hard drive cover.
      • Use the spudger to lift and to remove the hard drive cover.
      Pergunte ao FixBot
      Comentar
    3. Gateway SA1 Hard Drive Replacement: passo 5, imagem 1 %32 Gateway SA1 Hard Drive Replacement: passo 5, imagem 2 %32
      • Slide the original hard drive to the left and lift it to remove.
      • Insert the new hard drive.
      Pergunte ao FixBot
      Comentar
Conclusão
5 outras pessoas executaram este guia.
Equipe
Cal Poly, Team 24-20, Regan Spring 2010 Membro de Cal Poly, Team 24-20, Regan Spring 2010
CPSU-REGAN-S10S24G20
4 Membros
Autoria de 42 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 10
Últimos 30 dias: 37
Ao todo: 14,597
