Ir para o conteúdo principal
Gateway NV52 WiFi Card Replacement
O que você precisa
  1. Gateway NV52 WiFi Card Replacement, Base Cover: passo 1, imagem 1 %32
    • Remove the five identical 3/16" Phillips screws that secures the hard drive and memory cover using a Phillips #0 Screwdriver.
    Pergunte ao FixBot
    Comentar
  2. Gateway NV52 WiFi Card Replacement: passo 2, imagem 1 %32
    • Lift up the base cover from the the top with your hands to a 90 degree angle.
    • Remove the base cover and place it in a safe and dry place.
    Pergunte ao FixBot
    Comentar
  3. Gateway NV52 WiFi Card Replacement, WiFi Card: passo 3, imagem 1 %32
    • Remove the 3/16" screw located at the bottom left corner of the WiFi card using a Phillips #0 Screwdriver.
    Pergunte ao FixBot
    Comentar
  4. Gateway NV52 WiFi Card Replacement: passo 4, imagem 1 %32
    • Locate the black and white cables attached to the WiFi card.
    • Gently wiggle the black cable until it detaches from the WiFi card.
    • Repeat the previous step for the white cable.
    Pergunte ao FixBot
    Comentar
  5. Gateway NV52 WiFi Card Replacement: passo 5, imagem 1 %32
    • Gently, remove the Wifi card from its slot, and place it in a dry and safe place.
    Pergunte ao FixBot
    Comentar
Conclusão
Ruben
Membro desde: 04/22/14
298 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 7-24, Regan Spring 2014 Membro de Cal Poly, Team 7-24, Regan Spring 2014
CPSU-REGAN-S14S7G24
4 Membros
Autoria de 18 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 15
Últimos 30 dias: 33
Ao todo: 1,597
