Ir para o conteúdo principal
Gateway NV52 Keyboard Replacement
O que você precisa
  1. Gateway NV52 Keyboard Replacement, Battery: passo 1, imagem 1 %32
    • Turn the laptop on its backside with the stickers and barcode facing you.
    • Locate the latches on the top left corner.
    Pergunte ao FixBot
    Comentar
  2. Gateway NV52 Keyboard Replacement: passo 2, imagem 1 %32
    • In order to unlock the battery, slide the vertical latch downward where it indicates the unlocking icon.
    Pergunte ao FixBot
    Comentar
  3. Gateway NV52 Keyboard Replacement: passo 3, imagem 1 %32
    • Slide the horizontal latch to the right to pop open the battery pack.
    Pergunte ao FixBot
    Comentar
  4. Gateway NV52 Keyboard Replacement, Keyboard: passo 4, imagem 1 %32
    • Remove the five identical 9/32" Phillips Screws located under the battery and both upper corners using the Phillips #0 Screwdriver.
    Pergunte ao FixBot
    Comentar
  5. Gateway NV52 Keyboard Replacement: passo 5, imagem 1 %32
    Ferramenta utilizada neste passo:
    Heavy-Duty Spudger
    • Flip the Device so the keyboard and display screen are faced upright.
    • Lift up the media button board cover using the Heavy Duty Spudger. Apply a minimum amount of upward force to the media button board cover at the right bottom corner. Starting from the right, continuously lift the cover to the left edge until completely separated.
    • Do not lift up the media button board cover too much, it’s still connected to the motherboard. Set the media button board cover upside down on the keyboard.
    Pergunte ao FixBot
    Comentar
  6. Gateway NV52 Keyboard Replacement: passo 6, imagem 1 %32
    • Disconnect the dark colored locking tab by pulling at a 90 degree angle, and then slightly pull away the ribbon from the locking tab.
    Pergunte ao FixBot
    Comentar
  7. Gateway NV52 Keyboard Replacement: passo 7, imagem 1 %32
    • Lift up the keyboard with the Spudger. Rotate the keyboard until its faced down on top of its base.
    • The keyboard is still connected to the access keyboard connector, so do not attempt to detach the keyboard from the laptop, yet.
    Pergunte ao FixBot
    Comentar
  8. Gateway NV52 Keyboard Replacement: passo 8, imagem 1 %32
    • Disconnect the brown-colored locking tab by pulling at a 90 degree angle and slightly pulling away from the locking tab.
    • Do not apply too much force to the locking tab, because a damaged connector will disable the keyboard.
    • Remove the keyboard, and placed it in a safe and dry place.
    Pergunte ao FixBot
    Comentar
Conclusão
Tim En
Membro desde: 01/26/13
557 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 7-24, Regan Spring 2014 Membro de Cal Poly, Team 7-24, Regan Spring 2014
CPSU-REGAN-S14S7G24
4 Membros
Autoria de 18 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 41
Ao todo: 2,691
