Ir para o conteúdo principal
Gateway NV52 Cooling Fan Replacement
O que você precisa
  1. Gateway NV52 Cooling Fan  Replacement, Battery: passo 1, imagem 1 %32
    • Turn the laptop on its backside with the stickers and barcode facing you.
    • Locate the latches on the top left corner.
    Pergunte ao FixBot
    Comentar
  2. Gateway NV52 Cooling Fan  Replacement: passo 2, imagem 1 %32
    • In order to unlock the battery, slide the vertical latch downward where it indicates the unlocking icon.
    Pergunte ao FixBot
    Comentar
  3. Gateway NV52 Cooling Fan  Replacement: passo 3, imagem 1 %32
    • Slide the horizontal latch to the right to pop open the battery pack.
    Pergunte ao FixBot
    Comentar
  4. Gateway NV52 Cooling Fan  Replacement, Motherboard: passo 4, imagem 1 %32
    • Remove the five identical 3/16" Phillips #0 screws that secure the hard drive and memory cover.
    Pergunte ao FixBot
    Comentar
  5. Gateway NV52 Cooling Fan  Replacement: passo 5, imagem 1 %32
    • Lift up the base cover from the the top with your hands to a 90 degree angle.
    • Remove the base cover.
    Pergunte ao FixBot
    Comentar
  6. Gateway NV52 Cooling Fan  Replacement: passo 6, imagem 1 %32
    • Remove the 1/4" Phillips #0 screw located at the top right of the hard drive.
    Pergunte ao FixBot
    Comentar
  7. Gateway NV52 Cooling Fan  Replacement: passo 7, imagem 1 %32 Gateway NV52 Cooling Fan  Replacement: passo 7, imagem 2 %32 Gateway NV52 Cooling Fan  Replacement: passo 7, imagem 3 %32
    • Remove the hard drive component from its compartment. To do so, slide the component downward away from the battery pack.
    • Lift the hard drive to a 90 degree angle and out of its slot.
    Pergunte ao FixBot
    Comentar
  8. Gateway NV52 Cooling Fan  Replacement: passo 8, imagem 1 %32
    • Remove the 3/16" Phillips #0 screw located at the bottom left corner of the WiFi card.
    Pergunte ao FixBot
    Comentar
  9. Gateway NV52 Cooling Fan  Replacement: passo 9, imagem 1 %32
    • Locate the black and white cables attached to the WiFi card.
    • Gently wiggle the black cable until it detaches from the WiFi card.
    • Repeat the previous step for the white cable.
    Pergunte ao FixBot
    Comentar
  10. Gateway NV52 Cooling Fan  Replacement: passo 10, imagem 1 %32
    • Gently, remove the Wifi card from its slot, and place it in a dry and safe place.
    • Turn the laptop with the keyboard compartment facing up.
    Pergunte ao FixBot
    Comentar
  11. Gateway NV52 Cooling Fan  Replacement: passo 11, imagem 1 %32
    • Remove the five identical 9/32" Phillips #0 screws located under the battery and both upper corners.
    • Remove the 9/32" Phillips #0 screw fastening the optical disc drive.
    Pergunte ao FixBot
    Comentar
  12. Gateway NV52 Cooling Fan  Replacement: passo 12, imagem 1 %32
    • Using your hands, gently slide the optical drive out of the slot.
    Pergunte ao FixBot
    Comentar
  13. Gateway NV52 Cooling Fan  Replacement: passo 13, imagem 1 %32
    Ferramenta utilizada neste passo:
    Heavy-Duty Spudger
    • Flip the device so the keyboard and display screen are faced upright.
    • Lift up the media button board cover using the heavy duty spudger. Apply a minimum amount of upward force to the media button board cover at the right bottom corner. Starting from the right, continuously lift the cover to the left edge until completely separated.
    • Do not lift up the media button board cover too much, it’s still connected to the motherboard. Set the media button board cover upside down on the keyboard.
    Pergunte ao FixBot
    Comentar
  14. Gateway NV52 Cooling Fan  Replacement: passo 14, imagem 1 %32
    • Disconnect the dark colored locking tab by pulling at a 90 degree angle, and then slightly pull away the ribbon from the locking tab.
    Pergunte ao FixBot
    Comentar
  15. Gateway NV52 Cooling Fan  Replacement: passo 15, imagem 1 %32
    • Lift up the keyboard with the spudger. Rotate the keyboard until its face down on top of its base.
    • The keyboard is still connected to the access keyboard connector, so do not attempt to detach the keyboard from the laptop, yet.
    Pergunte ao FixBot
    Comentar
  16. Gateway NV52 Cooling Fan  Replacement: passo 16, imagem 1 %32
    • Disconnect the brown-colored locking tab by pulling at a 90 degree angle and slightly pulling away from the locking tab.
    • Do not apply too much force to the locking tab, because a damaged connector will disable the keyboard.
    • Remove the keyboard.
    Pergunte ao FixBot
    Comentar
  17. Gateway NV52 Cooling Fan  Replacement: passo 17, imagem 1 %32
    • Locate the three LCD connectors.
    Pergunte ao FixBot
    Comentar
  18. Gateway NV52 Cooling Fan  Replacement: passo 18, imagem 1 %32 Gateway NV52 Cooling Fan  Replacement: passo 18, imagem 2 %32 Gateway NV52 Cooling Fan  Replacement: passo 18, imagem 3 %32
    • Use the pointy end of the spudger to gently pry each side of the LCD connector until they are detached from their respective ports.
    • Do not pull with excessive force, since it could damage the LCD cable plug-in.
    Pergunte ao FixBot
    Comentar
  19. Gateway NV52 Cooling Fan  Replacement: passo 19, imagem 1 %32
    • Using the flat edge of the spudger, disconnect the big white LCD cable connector by slightly pulling on it until it's detached from its respective port.
    Pergunte ao FixBot
    Comentar
  20. Gateway NV52 Cooling Fan  Replacement: passo 20, imagem 1 %32
    • Using the tweezers, pull out the black and white cables located at the right side of the laptop.
    Pergunte ao FixBot
    Comentar
  21. Gateway NV52 Cooling Fan  Replacement: passo 21, imagem 1 %32 Gateway NV52 Cooling Fan  Replacement: passo 21, imagem 2 %32
    • Remove the two 9/32" Phillips #0 screws on the top left and right corners.
    • Lift the entire display screen straight up using both hands.
    Pergunte ao FixBot
    Comentar
  22. Gateway NV52 Cooling Fan  Replacement: passo 22, imagem 1 %32
    • Turn the laptop upside down.
    • Remove ten 9/32" screws with a Phillips #0 Screwdriver.
    Pergunte ao FixBot
    Comentar
  23. Gateway NV52 Cooling Fan  Replacement: passo 23, imagem 1 %32
    • Flip the laptop over.
    • Remove the three 9/32"screws that secures the top cover with a Phillips #0 screwdriver.
    Pergunte ao FixBot
    Comentar
  24. Gateway NV52 Cooling Fan  Replacement: passo 24, imagem 1 %32
    • Gently disconnect the two ribbons from the motherboard using the black tweezers.
    Pergunte ao FixBot
    Comentar
  25. Gateway NV52 Cooling Fan  Replacement: passo 25, imagem 1 %32
    • Separate the top cover from the base using the heavy duty spudger. Insert the spudger in between the keyboard base and the base of the laptop with a minimum amount of force to separate them. Follow this procedure around the perimeter until the parts are separated.
    Pergunte ao FixBot
    Comentar
  26. Gateway NV52 Cooling Fan  Replacement: passo 26, imagem 1 %32
    • Remove the 3/16" screw securing the motherboard with a Phillips #0 screwdriver.
    Pergunte ao FixBot
    Comentar
  27. Gateway NV52 Cooling Fan  Replacement: passo 27, imagem 1 %32
    • Cautiously disconnect the USB board cable that is situated on the top right corner of the motherboard.
    Pergunte ao FixBot
    Comentar
  28. Gateway NV52 Cooling Fan  Replacement: passo 28, imagem 1 %32
    • Disconnect the modem cable located at the bottom right of the motherboard.
    Pergunte ao FixBot
    Comentar
  29. Gateway NV52 Cooling Fan  Replacement: passo 29, imagem 1 %32
    • Cautiously remove the motherboard and lie it down.
    Pergunte ao FixBot
    Comentar
  30. Gateway NV52 Cooling Fan  Replacement, Cooling Fan: passo 30, imagem 1 %32
    • Loosen the four 13/32" screws that connects the cooling fan to the motherboard using the Phillips #0 Screwdriver.
    • The four 13/32" Phillip screws do not come off the metal fan support. Do not force to take the screws off, else the screw attachment can get damaged.
    Pergunte ao FixBot
    Comentar
  31. Gateway NV52 Cooling Fan  Replacement: passo 31, imagem 1 %32
    • Disconnect the fan cable from the motherboard.
    • Do not pull on the fan cable will excessive force. It will result with a non-working cooling fan and a damaged wire.
    Pergunte ao FixBot
    Comentar
  32. Gateway NV52 Cooling Fan  Replacement: passo 32, imagem 1 %32
    • Carefully lift up and remove the cooling fan using your hands, and place it in a dry and safe zone.
    Pergunte ao FixBot
    Comentar
Conclusão
Ruben
Membro desde: 04/22/14
298 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 7-24, Regan Spring 2014 Membro de Cal Poly, Team 7-24, Regan Spring 2014
CPSU-REGAN-S14S7G24
4 Membros
Autoria de 18 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 17
Ao todo: 3,533
