Ir para o conteúdo principal
Gateway NE52203u Wireless Card Replacement
O que você precisa
  1. Gateway NE52203u Wireless Card Replacement, Battery: passo 1, imagem 1 %32
    • Flip the device over onto its backside in order to access the battery.
    Pergunte ao FixBot
    Comentar
  2. Gateway NE52203u Wireless Card Replacement: passo 2, imagem 1 %32 Gateway NE52203u Wireless Card Replacement: passo 2, imagem 2 %32
    • Locate the battery release latch and slide it over to the other side.
    • A small tool like a pen or screwdriver may be helpful in sliding the latch to release the battery.
    Pergunte ao FixBot
    Comentar
  3. Gateway NE52203u Wireless Card Replacement: passo 3, imagem 1 %32
    • Grab the newly ejected battery from the device to completely remove it.
    • When reinserting the new battery, make sure the prongs on the battery are aligned with the corresponding holes on the laptop.
    Pergunte ao FixBot
    Comentar
  4. Gateway NE52203u Wireless Card Replacement, Touchpad Assembly: passo 4, imagem 1 %32 Gateway NE52203u Wireless Card Replacement, Touchpad Assembly: passo 4, imagem 2 %32
    • Remove 18 6.0 mm Phillips #00 screws from the bottom of the laptop.
    • Remove 5 6.0 mm Phillip #00 screws from under cover.
    Pergunte ao FixBot
    Comentar
  5. Gateway NE52203u Wireless Card Replacement: passo 5, imagem 1 %32
    • Remove three 2.9 mm Phillips #00 screws from the battery compartment.
    Pergunte ao FixBot
    Comentar
  6. Gateway NE52203u Wireless Card Replacement: passo 6, imagem 1 %32 Gateway NE52203u Wireless Card Replacement: passo 6, imagem 2 %32
    • Separate the bottom panel from the touchpad assembly by inserting a plastic opening tool between them on all four sides.
    Pergunte ao FixBot
    Comentar
  7. Gateway NE52203u Wireless Card Replacement: passo 7, imagem 1 %32
    Ferramenta utilizada neste passo:
    • Pull black ribbon wire from port using tweezers in order to completely separate touchpad assembly from bottom assembly.
    Pergunte ao FixBot
    Comentar
  8. Gateway NE52203u Wireless Card Replacement: passo 8, imagem 1 %32 Gateway NE52203u Wireless Card Replacement: passo 8, imagem 2 %32 Gateway NE52203u Wireless Card Replacement: passo 8, imagem 3 %32
    • Disconnect the two ZIF ports that attach the touchpad assembly to the motherboard.
    • First flip open the flap covering the ribbon using a spudger or fingernail.
    • Second gently pull the ribbon away from the port.
    Pergunte ao FixBot
    Comentar
  9. Gateway NE52203u Wireless Card Replacement, Wireless Card: passo 9, imagem 1 %32 Gateway NE52203u Wireless Card Replacement, Wireless Card: passo 9, imagem 2 %32
    • Grab the antenna cable with tweezers and lift up to pull it off.
    • The antenna is the small black cable with the golden head
    Pergunte ao FixBot
    Comentar
  10. Gateway NE52203u Wireless Card Replacement: passo 10, imagem 1 %32
    • Remove the one 2.9 mm Phillips #00 screw holding down the wireless card in place.
    Pergunte ao FixBot
    Comentar
  11. Gateway NE52203u Wireless Card Replacement: passo 11, imagem 1 %32
    • After the screw is removed, the card will spring upwards slightly. Pull out the old wireless card from its port.
    Pergunte ao FixBot
    Comentar
Conclusão
Stephen Spees
Membro desde: 03/20/15
542 Reputação
Autoria de 4 guias
Equipe
Baylor, Team 2-1, Grigsby Spring 2015 Membro de Baylor, Team 2-1, Grigsby Spring 2015
BU-GRIGSBY-S15S2G1
4 Membros
Autoria de 10 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 22
Ao todo: 871
