Ir para o conteúdo principal
Gateway NE52203u Optical Drive Replacement
O que você precisa
  1. Gateway NE52203u Optical Drive Replacement, Battery: passo 1, imagem 1 %32
    • Flip the device over onto its backside in order to access the battery.
    Pergunte ao FixBot
    Comentar
  2. Gateway NE52203u Optical Drive Replacement: passo 2, imagem 1 %32 Gateway NE52203u Optical Drive Replacement: passo 2, imagem 2 %32
    • Locate the battery release latch and slide it over to the other side.
    • A small tool like a pen or screwdriver may be helpful in sliding the latch to release the battery.
    Pergunte ao FixBot
    Comentar
  3. Gateway NE52203u Optical Drive Replacement: passo 3, imagem 1 %32
    • Grab the newly ejected battery from the device to completely remove it.
    • When reinserting the new battery, make sure the prongs on the battery are aligned with the corresponding holes on the laptop.
    Pergunte ao FixBot
    Comentar
  4. Gateway NE52203u Optical Drive Replacement, Touchpad Assembly: passo 4, imagem 1 %32 Gateway NE52203u Optical Drive Replacement, Touchpad Assembly: passo 4, imagem 2 %32
    • Remove 18 6.0 mm Phillips #00 screws from the bottom of the laptop.
    • Remove 5 6.0 mm Phillip #00 screws from under cover.
    Pergunte ao FixBot
    Comentar
  5. Gateway NE52203u Optical Drive Replacement: passo 5, imagem 1 %32
    • Remove three 2.9 mm Phillips #00 screws from the battery compartment.
    Pergunte ao FixBot
    Comentar
  6. Gateway NE52203u Optical Drive Replacement: passo 6, imagem 1 %32 Gateway NE52203u Optical Drive Replacement: passo 6, imagem 2 %32
    • Separate the bottom panel from the touchpad assembly by inserting a plastic opening tool between them on all four sides.
    Pergunte ao FixBot
    Comentar
  7. Gateway NE52203u Optical Drive Replacement: passo 7, imagem 1 %32
    Ferramenta utilizada neste passo:
    • Pull black ribbon wire from port using tweezers in order to completely separate touchpad assembly from bottom assembly.
    Pergunte ao FixBot
    Comentar
  8. Gateway NE52203u Optical Drive Replacement: passo 8, imagem 1 %32 Gateway NE52203u Optical Drive Replacement: passo 8, imagem 2 %32 Gateway NE52203u Optical Drive Replacement: passo 8, imagem 3 %32
    • Disconnect the two ZIF ports that attach the touchpad assembly to the motherboard.
    • First flip open the flap covering the ribbon using a spudger or fingernail.
    • Second gently pull the ribbon away from the port.
    Pergunte ao FixBot
    Comentar
  9. Gateway NE52203u Optical Drive Replacement, Optical Drive: passo 9, imagem 1 %32 Gateway NE52203u Optical Drive Replacement, Optical Drive: passo 9, imagem 2 %32 Gateway NE52203u Optical Drive Replacement, Optical Drive: passo 9, imagem 3 %32
    • Grasp the plastic placeholder firmly and slide it out of the computer.
    • When inserting replacement optical drive, use the port at the back left of the open space.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Stephen Spees
Membro desde: 03/20/15
542 Reputação
Autoria de 4 guias
Equipe
Baylor, Team 2-1, Grigsby Spring 2015 Membro de Baylor, Team 2-1, Grigsby Spring 2015
BU-GRIGSBY-S15S2G1
4 Membros
Autoria de 10 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 23
Ao todo: 710
