Ir para o conteúdo principal
Gateway MS2370 Keyboard Replacement
O que você precisa
    1. Gateway MS2370 Keyboard Replacement, Battery: passo 1, imagem 1 %32
      • Make sure the laptop is turned off and flipped over so that the bottom is facing up. Then, locate the battery clip as shown.
      Pergunte ao FixBot
      Comentar
    2. Gateway MS2370 Keyboard Replacement: passo 2, imagem 1 %32
      • Either using your fingers or a plastic spudger push the battery clip to the left to release battery.
      Pergunte ao FixBot
      Comentar
    3. Gateway MS2370 Keyboard Replacement: passo 3, imagem 1 %32
      • Pull the battery from the laptop to remove it.
      Pergunte ao FixBot
      Comentar
    1. Gateway MS2370 Keyboard Replacement, Keyboard: passo 4, imagem 1 %32
      • Take the plastic spudger and pull up the tabs on all four sides of the keyboard molding.
      Pergunte ao FixBot
      Comentar
    2. Gateway MS2370 Keyboard Replacement: passo 5, imagem 1 %32
      • Carefully lift the keyboard molding out.
      Pergunte ao FixBot
      Comentar
    3. Gateway MS2370 Keyboard Replacement: passo 6, imagem 1 %32
      • Use the plastic spudger again to pry the keyboard tabs from the laptop.
      Pergunte ao FixBot
      Comentar
    4. Gateway MS2370 Keyboard Replacement: passo 7, imagem 1 %32
      • Slowly lift the keyboard from the laptop.
      Pergunte ao FixBot
      Comentar
    5. Gateway MS2370 Keyboard Replacement: passo 8, imagem 1 %32 Gateway MS2370 Keyboard Replacement: passo 8, imagem 2 %32
      • Carefully unplug the ribbon cable attached to the motherboard.
      • The ribbon cable is extremely delicate, handle with care
      Pergunte ao FixBot
      Comentar
    6. Gateway MS2370 Keyboard Replacement: passo 9, imagem 1 %32
      • Lift and remove the keyboard from the computer.
      Pergunte ao FixBot
      Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 25
Ao todo: 1,228
