Ir para o conteúdo principal
Gateway MS2285 RAM Replacement
O que você precisa
  1. Gateway MS2285 RAM Replacement, Turn Laptop Over: passo 1, imagem 1 %32
    • Turn the laptop over so that the underside is facing towards you.
    Pergunte ao FixBot
    Comentar
  2. Gateway MS2285 RAM Replacement, Unlock The Battery: passo 2, imagem 1 %32 Gateway MS2285 RAM Replacement, Unlock The Battery: passo 2, imagem 2 %32
    • Slide the short slider one towards the unlocked lock symbol.
    Pergunte ao FixBot
    Comentar
  3. Gateway MS2285 RAM Replacement, Release The Battery: passo 3, imagem 1 %32 Gateway MS2285 RAM Replacement, Release The Battery: passo 3, imagem 2 %32
    • Slide the long slider towards the unlocked lock icon.
    • This slider is spring loaded and may require a little force.
    • If done correctly, a click will be heard and the battery will be slightly raised.
    Pergunte ao FixBot
    Comentar
  4. Gateway MS2285 RAM Replacement, Remove The Battery: passo 4, imagem 1 %32 Gateway MS2285 RAM Replacement, Remove The Battery: passo 4, imagem 2 %32
    • Grasp the battery's raised end and lift upwards.
    Pergunte ao FixBot
    Comentar
  5. Gateway MS2285 RAM Replacement, Unscrew Backplate: passo 5, imagem 1 %32 Gateway MS2285 RAM Replacement, Unscrew Backplate: passo 5, imagem 2 %32
    • Use the phillips head screwdriver to remove the five screws holding the back plate.
    • The screws are counter-clockwise threaded.
    Pergunte ao FixBot
    Comentar
  6. Gateway MS2285 RAM Replacement, Remove Back Plate: passo 6, imagem 1 %32 Gateway MS2285 RAM Replacement, Remove Back Plate: passo 6, imagem 2 %32 Gateway MS2285 RAM Replacement, Remove Back Plate: passo 6, imagem 3 %32
    • Place fingers under back plate via the indentation and lift upwards to remove.
    Pergunte ao FixBot
    Comentar
  7. Gateway MS2285 RAM Replacement, Unlock Upper RAM Module: passo 7, imagem 1 %32 Gateway MS2285 RAM Replacement, Unlock Upper RAM Module: passo 7, imagem 2 %32 Gateway MS2285 RAM Replacement, Unlock Upper RAM Module: passo 7, imagem 3 %32
    • Push the upper RAM module's two pins outwards at the same time.
    • If done correctly, the module should have lifted.
    Pergunte ao FixBot
    Comentar
  8. Gateway MS2285 RAM Replacement, Remove Upper RAM Module: passo 8, imagem 1 %32 Gateway MS2285 RAM Replacement, Remove Upper RAM Module: passo 8, imagem 2 %32
    • Grab onto the module and pull away in a straight direction.
    • Do not touch the gold connectors.
    Pergunte ao FixBot
    Comentar
  9. Gateway MS2285 RAM Replacement, Unlock Lower RAM Module: passo 9, imagem 1 %32 Gateway MS2285 RAM Replacement, Unlock Lower RAM Module: passo 9, imagem 2 %32 Gateway MS2285 RAM Replacement, Unlock Lower RAM Module: passo 9, imagem 3 %32
    • Push the lower RAM module's two pins outwards at the same time.
    Pergunte ao FixBot
    Comentar
  10. Gateway MS2285 RAM Replacement, Remove Lower RAM Module: passo 10, imagem 1 %32 Gateway MS2285 RAM Replacement, Remove Lower RAM Module: passo 10, imagem 2 %32 Gateway MS2285 RAM Replacement, Remove Lower RAM Module: passo 10, imagem 3 %32
    • Like removing the upper module, grab the module and pull away in a straight direction.
    Pergunte ao FixBot
    Comentar
Conclusão
Chris mello
Membro desde: 10/22/14
331 Reputação
Autoria de 3 guias
Equipe
UMass Dartmouth, Team 1-7, Shastany Fall 2014 Membro de UMass Dartmouth, Team 1-7, Shastany Fall 2014
UMASSD-SHASTANY-F14S1G7
3 Membros
Autoria de 6 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 24
Ao todo: 2,916
