Ir para o conteúdo principal
Gateway MD2614u Wireless Card Replacement
O que você precisa
    1. Gateway MD2614u Wireless Card Replacement, Back Cover: passo 1, imagem 1 %32
      • Place the laptop so the back cover is facing up.
      Pergunte ao FixBot
      Comentar
    2. Gateway MD2614u Wireless Card Replacement: passo 2, imagem 1 %32
      • Remove the 8 screws from the back cover using the Phillips #00 screwdriver.
      Pergunte ao FixBot
      Comentar
    3. Gateway MD2614u Wireless Card Replacement: passo 3, imagem 1 %32
      • Lift off the cover.
      Pergunte ao FixBot
      Comentar
    1. Gateway MD2614u Wireless Card Replacement, Wireless Card: passo 4, imagem 1 %32
      • The wireless card is located to the right of the hard drive and below the RAM.
      Pergunte ao FixBot
      Comentar
    2. Gateway MD2614u Wireless Card Replacement: passo 5, imagem 1 %32
      • There are black and grey wires with gold heads attached to the top of the wireless card.
      • To remove these wires, turn the gold heads counterclockwise and pull up.
      • You will hear a snap when the heads come off.
      • It does not matter which wire you remove first, but do so one at a time.
      Pergunte ao FixBot
      Comentar
    3. Gateway MD2614u Wireless Card Replacement: passo 6, imagem 1 %32
      • Remove the two screws next to the wires with a Phillips #00 screwdriver.
      Pergunte ao FixBot
      Comentar
    4. Gateway MD2614u Wireless Card Replacement: passo 7, imagem 1 %32
      • The card will pop up 20 degrees and is loose enough to remove with your hand.
      • Carefully pull the card out to the left horizontally.
      Pergunte ao FixBot
      Comentar
Conclusão
Toni Pipes
Membro desde: 10/05/10
333 Reputação
Autoria de 7 guias
Equipe
Cal Poly, Team 21-31, Regan Fall 2010 Membro de Cal Poly, Team 21-31, Regan Fall 2010
CPSU-REGAN-F10S21G31
4 Membros
Autoria de 41 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 4
Últimos 30 dias: 30
Ao todo: 4,766
