Ir para o conteúdo principal
Gateway MA7 Fan Replacement
O que você precisa
    1. Gateway MA7 Fan Replacement, Fan: passo 1, imagem 1 %32
      • Before starting this replacement, make sure the device is powered off and the battery is removed.
      • This particular device is missing the battery.
      • To remove your battery, slide the plastic tabs on the back of the laptop and pull the battery out of the device.
      Pergunte ao FixBot
      Comentar
    2. Gateway MA7 Fan Replacement: passo 2, imagem 1 %32 Gateway MA7 Fan Replacement: passo 2, imagem 2 %32 Gateway MA7 Fan Replacement: passo 2, imagem 3 %32
      • Remove the seven 6mm screws from the back panel with a Phillips #0 screwdriver.
      Pergunte ao FixBot
      Comentar
    3. Gateway MA7 Fan Replacement: passo 3, imagem 1 %32 Gateway MA7 Fan Replacement: passo 3, imagem 2 %32 Gateway MA7 Fan Replacement: passo 3, imagem 3 %32
      • Pull upwards on the top of the plastic panel to remove it.
      • With the exception of the screw marked "K", all of the screws will remain connected to the plastic piece.
      Pergunte ao FixBot
      Comentar
    4. Gateway MA7 Fan Replacement: passo 4, imagem 1 %32 Gateway MA7 Fan Replacement: passo 4, imagem 2 %32
      • Remove the five 6 mm screws with a Phillips #0 screw driver to detach the fan and cooling unit from the motherboard.
      • The four screws on the silver metal bands of the fan will not come off of the actual component.
      Pergunte ao FixBot
      Comentar
    5. Gateway MA7 Fan Replacement: passo 5, imagem 1 %32 Gateway MA7 Fan Replacement: passo 5, imagem 2 %32 Gateway MA7 Fan Replacement: passo 5, imagem 3 %32
      • Lifting from the left side of the fan, start to pull the fan off of the motherboard.
      • Be sure not to pull the fan all the way off the motherboard yet. Before it can be completely removed the cables must be disconnected.
      • There may be thermal paste adhering the fan to the motherboard. Be sure to lift the fan slowly and gently.
      Pergunte ao FixBot
      Comentar
    6. Gateway MA7 Fan Replacement: passo 6, imagem 1 %32 Gateway MA7 Fan Replacement: passo 6, imagem 2 %32 Gateway MA7 Fan Replacement: passo 6, imagem 3 %32
      • In order to properly remove the fan, disconnect the cable that is attached to the motherboard.
      • Gently grasp the connecting cable from under the fan and pull it out of the socket on the motherboard to disconnect it.
      Pergunte ao FixBot
      Comentar
    7. Gateway MA7 Fan Replacement: passo 7, imagem 1 %32 Gateway MA7 Fan Replacement: passo 7, imagem 2 %32 Gateway MA7 Fan Replacement: passo 7, imagem 3 %32
      • With the screws removed and the cable disconnected, just lift the fan off the motherboard to remove it.
      • When you replace the fan, be sure to reapply thermal paste here.
      Pergunte ao FixBot
      Comentar
Conclusão
Cameron Sheedy
Membro desde: 03/05/18
145 Reputação
Autoria de 1 guia
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 43
Ao todo: 912
