Ir para o conteúdo principal
Gateway MA6 Laptop RAM Replacement
O que você precisa
  1. Gateway MA6 Laptop RAM Replacement, Battery: passo 1, imagem 1 %32
    • To prevent injury, make sure the laptop is unplugged before removing the battery.
    • Make sure the switch in the upper right corner of the laptop is switched to the "unlock" position (toward the unlocked padlock icon).
    Pergunte ao FixBot
    Comentar
  2. Gateway MA6 Laptop RAM Replacement: passo 2, imagem 1 %32 Gateway MA6 Laptop RAM Replacement: passo 2, imagem 2 %32 Gateway MA6 Laptop RAM Replacement: passo 2, imagem 3 %32
    • Pull the switch on the upper lefthand corner of the laptop towards the unlocked padlock icon.
    • Firmly pull the battery outwards and away from the laptop.
    Pergunte ao FixBot
    Comentar
  3. Gateway MA6 Laptop RAM Replacement, RAM: passo 3, imagem 1 %32 Gateway MA6 Laptop RAM Replacement, RAM: passo 3, imagem 2 %32
    • Remove the seven 6 mm Phillips #0 screws from the back of the case.
    • Leave all the screws in the back plate and so you don't lose them.
    Pergunte ao FixBot
    Comentar
  4. Gateway MA6 Laptop RAM Replacement: passo 4, imagem 1 %32 Gateway MA6 Laptop RAM Replacement: passo 4, imagem 2 %32
    • Pull upwards on the top of the back cover to remove it.
    Pergunte ao FixBot
    Comentar
  5. Gateway MA6 Laptop RAM Replacement: passo 5, imagem 1 %32 Gateway MA6 Laptop RAM Replacement: passo 5, imagem 2 %32 Gateway MA6 Laptop RAM Replacement: passo 5, imagem 3 %32
    • Pull outwards on the silver metal pins to release the upper RAM module.
    • The module will automatically lift up 30° after it has been released.
    Pergunte ao FixBot
    Comentar
  6. Gateway MA6 Laptop RAM Replacement: passo 6, imagem 1 %32 Gateway MA6 Laptop RAM Replacement: passo 6, imagem 2 %32
    • Firmly grasp the outer portion of the RAM module, and pull it outward to remove it from the port.
    • Repeat the same process for the lower RAM module.
    Pergunte ao FixBot
    Comentar
Conclusão
Equipe
Cal Poly, Team 6-2, Forte Spring 2014 Membro de Cal Poly, Team 6-2, Forte Spring 2014
CPSU-FORTE-S14S6G2
5 Membros
Autoria de 20 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 8
Últimos 30 dias: 39
Ao todo: 1,551
