Ir para o conteúdo principal
Gateway MA6 Laptop Cooling Assembly Replacement
O que você precisa
  1. Gateway MA6 Laptop Cooling Assembly Replacement, Cooling Assembly: passo 1, imagem 1 %32 Gateway MA6 Laptop Cooling Assembly Replacement, Cooling Assembly: passo 1, imagem 2 %32
    • Loosen the seven 6 mm Phillips #0 screws on the back of the case.
    • Leave all the screws in the back plate and so you don't lose them.
  2. Gateway MA6 Laptop Cooling Assembly Replacement: passo 2, imagem 1 %32 Gateway MA6 Laptop Cooling Assembly Replacement: passo 2, imagem 2 %32
    • Pull upwards on the top of the back cover to remove it.
  3. Gateway MA6 Laptop Cooling Assembly Replacement: passo 3, imagem 1 %32
    • Remove the four 9 mm Phillips #0 screws from the cooling assembly.
  4. Gateway MA6 Laptop Cooling Assembly Replacement: passo 4, imagem 1 %32 Gateway MA6 Laptop Cooling Assembly Replacement: passo 4, imagem 2 %32 Gateway MA6 Laptop Cooling Assembly Replacement: passo 4, imagem 3 %32
    • Gently and carefully remove the cooling assembly to avoid ripping the wire attaching it to the computer.
    • Gently flip the cooling fan assembly upside-down on the computer surface.
    • Carefully grab the wire attached to the computer and pull away from the port.
    • The cooling fan is now safe for removal.
  5. Gateway MA6 Laptop Cooling Assembly Replacement: passo 5, imagem 1 %32
    • When reinstalling heat sink and fans clean off the old thermal paste from both the heat sink and the CPU and then add new paste to CPU
    • If your unfamiliar with applying thermal paste How to Apply Thermal Paste
Conclusão
Chris Naughton
Membro desde: 04/07/14
705 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 6-2, Forte Spring 2014 Membro de Cal Poly, Team 6-2, Forte Spring 2014
CPSU-FORTE-S14S6G2
5 Membros
Autoria de 20 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 8
Ao todo: 839
