Ir para o conteúdo principal
Gateway Lt4004u Keyboard Replacement
O que você precisa
    1. Gateway Lt4004u Keyboard Replacement, Battery: passo 1, imagem 1 %32 Gateway Lt4004u Keyboard Replacement, Battery: passo 1, imagem 2 %32 Gateway Lt4004u Keyboard Replacement, Battery: passo 1, imagem 3 %32
      • Place the laptop face down in front of you.
      • Locate the battery lock switches on the left and right top corners of the bottom of the device indicated by the red circles.
      • Pinch the switches and slide toward the edges of the computer to unlock.
      Pergunte ao FixBot
      Comentar
    2. Gateway Lt4004u Keyboard Replacement: passo 2, imagem 1 %32 Gateway Lt4004u Keyboard Replacement: passo 2, imagem 2 %32
      • Once the switches have both been unlocked, push the battery upwards away from the rest of the laptop.
      • Remove the battery from the laptop.
      Pergunte ao FixBot
      Comentar
    1. Gateway Lt4004u Keyboard Replacement, Keyboard: passo 3, imagem 1 %32 Gateway Lt4004u Keyboard Replacement, Keyboard: passo 3, imagem 2 %32 Gateway Lt4004u Keyboard Replacement, Keyboard: passo 3, imagem 3 %32
      • Open the laptop so that the screen and keyboard are facing you.
      • Identify the 5 tabs above the function keys in the crevice that attaches the keyboard to the main frame.
      Pergunte ao FixBot
      Comentar
    2. Gateway Lt4004u Keyboard Replacement: passo 4, imagem 1 %32 Gateway Lt4004u Keyboard Replacement: passo 4, imagem 2 %32 Gateway Lt4004u Keyboard Replacement: passo 4, imagem 3 %32
      • Use an opening pick to push each tab away from you.
      • Use an opening tool to push the middle tab until you hear a click. Begin to push the tool downward into the computer and slide the card along the length of the keyboard, as you overcome the five tabs.
      • A clicking sound is normal and no cause for alarm.
      Pergunte ao FixBot
      Comentar
    3. Gateway Lt4004u Keyboard Replacement: passo 5, imagem 1 %32 Gateway Lt4004u Keyboard Replacement: passo 5, imagem 2 %32 Gateway Lt4004u Keyboard Replacement: passo 5, imagem 3 %32
      Ferramenta utilizada neste passo:
      Plastic Cards
      $2.99
      • Begin to slide the plastic card under the top edge of the keyboard. You will hear popping sounds and the keyboard will eventually be released.
      • Carefully pry the keyboard from the main frame, starting at the top section.
      • Look at the intel sticker in this step and the next to orient your computer with the pictures.
      Pergunte ao FixBot
      Comentar
    4. Gateway Lt4004u Keyboard Replacement: passo 6, imagem 1 %32 Gateway Lt4004u Keyboard Replacement: passo 6, imagem 2 %32
      • Look at the intel sticker in this step and the previous step to orient your computer with the pictures.
      • Unplug the thin blue connection piece beneath the keyboard. It may pop off on its own while you are prying off the keyboard.
      • The popping noise will not hurt the computer.
      • Once the thin blue plastic has been detached, remove the keyboard from the rest of the laptop.
      Pergunte ao FixBot
      Comentar
Conclusão
Equipe
Clemson, Team 6-5, Benson Spring 2016 Membro de Clemson, Team 6-5, Benson Spring 2016
CLEM-BENSON-S16S6G5
4 Membros
Autoria de 48 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 9
Últimos 30 dias: 22
Ao todo: 916
