Ir para o conteúdo principal
Gateway LT41P10u Webcam Replacement
O que você precisa
  1. Gateway LT41P10u Webcam Replacement, Battery: passo 1, imagem 1 %32
    • Place the laptop upside down on a flat surface so you can see the battery.
    Pergunte ao FixBot
    Comentar
  2. Gateway LT41P10u Webcam Replacement: passo 2, imagem 1 %32
    • Pull the two marked tabs towards the outside of the computer to unlock them.
    Pergunte ao FixBot
    Comentar
  3. Gateway LT41P10u Webcam Replacement: passo 3, imagem 1 %32
    • While keeping both of the tabs in the unlocked position, grab the battery and pull outwards, until the battery slides out from the rest of the computer.
    Pergunte ao FixBot
    Comentar
  4. Gateway LT41P10u Webcam Replacement, Monitor: passo 4, imagem 1 %32 Gateway LT41P10u Webcam Replacement, Monitor: passo 4, imagem 2 %32
    • Carefully use a spudger to separate the monitor from top panel.
    • Gently remove lower hooks from the hinges. (see second image)
    Pergunte ao FixBot
    Comentar
  5. Gateway LT41P10u Webcam Replacement: passo 5, imagem 1 %32 Gateway LT41P10u Webcam Replacement: passo 5, imagem 2 %32
    • Once you completed separating the monitor from the top panel disconnect the cable shown here in red by raising the cable lock and pulling the wires away.
    • The second image is how it should look once completely disconnected.
    Pergunte ao FixBot
    Comentar
  6. Gateway LT41P10u Webcam Replacement, Webcam: passo 6, imagem 1 %32
    • Using a plastic spudger or fingers gently remove webcam hardware from front screen. A gentle heat source can be used to easily remove glued down parts.
    • Once webcam hardware is removed from front screen, it can be removed by hand from the wiring and replaced.
    • Perform these steps carefully as smaller parts are more likely to break.
    Pergunte ao FixBot
    Comentar
Conclusão
Patrick Raposo
Membro desde: 10/21/17
201 Reputação
Autoria de 2 guias
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 6
Últimos 30 dias: 29
Ao todo: 373
