Ir para o conteúdo principal
Gateway LT41P10u Monitor Replacement
O que você precisa
  1. Gateway LT41P10u Monitor Replacement, Battery: passo 1, imagem 1 %32
    • Place the laptop upside down on a flat surface so you can see the battery.
    Pergunte ao FixBot
    Comentar
  2. Gateway LT41P10u Monitor Replacement: passo 2, imagem 1 %32
    • Pull the two marked tabs towards the outside of the computer to unlock them.
    Pergunte ao FixBot
    Comentar
  3. Gateway LT41P10u Monitor Replacement: passo 3, imagem 1 %32
    • While keeping both of the tabs in the unlocked position, grab the battery and pull outwards, until the battery slides out from the rest of the computer.
    Pergunte ao FixBot
    Comentar
  4. Gateway LT41P10u Monitor Replacement, Monitor: passo 4, imagem 1 %32 Gateway LT41P10u Monitor Replacement, Monitor: passo 4, imagem 2 %32
    • Carefully use a spudger to separate the monitor from top panel.
    • Gently remove lower hooks from the hinges. (see second image)
    Pergunte ao FixBot
    Comentar
  5. Gateway LT41P10u Monitor Replacement: passo 5, imagem 1 %32 Gateway LT41P10u Monitor Replacement: passo 5, imagem 2 %32
    • Once you completed separating the monitor from the top panel disconnect the cable shown here in red by raising the cable lock and pulling the wires away.
    • The second image is how it should look once completely disconnected.
    Pergunte ao FixBot
    Comentar
Conclusão
To reinstall your device, follow these instructions in reverse order.
Michael Smith
Membro desde: 10/19/17
401 Reputação
Autoria de 4 guias
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 25
Ao todo: 518
