Ir para o conteúdo principal
Gateway LT4004u Screen Replacement
O que você precisa
  1. Gateway LT4004u Screen Replacement, Screen: passo 1, imagem 1 %32 Gateway LT4004u Screen Replacement, Screen: passo 1, imagem 2 %32 Gateway LT4004u Screen Replacement, Screen: passo 1, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Open the laptop so that the screen and keyboard are facing you.
    • Remove the two screw covers at the bottom right and left corners of the screen using tweezers.
    Pergunte ao FixBot
    Comentar
  2. Gateway LT4004u Screen Replacement: passo 2, imagem 1 %32 Gateway LT4004u Screen Replacement: passo 2, imagem 2 %32 Gateway LT4004u Screen Replacement: passo 2, imagem 3 %32
    • Unscrew the two 5.0mm screws underneath the screen covers on the left and right side and remove them from the laptop. For this step and the following steps, use a Phillips #0 head screwdriver.
    Pergunte ao FixBot
    Comentar
  3. Gateway LT4004u Screen Replacement: passo 3, imagem 1 %32 Gateway LT4004u Screen Replacement: passo 3, imagem 2 %32 Gateway LT4004u Screen Replacement: passo 3, imagem 3 %32
    • Once the two screws are removed, pry the screen casing away from the screen. You can use your fingernails or a tool such as tweezers to separate the screen casing from the backing.
    • Be prepared to hear cracking noises. These are expected.
    • Unhook the screen casing at the bottom of the screen from the central hinges on the left and right side connecting the screen casing to the keyboard.
    • Remove the screen casing.
    Pergunte ao FixBot
    Comentar
  4. Gateway LT4004u Screen Replacement: passo 4, imagem 1 %32 Gateway LT4004u Screen Replacement: passo 4, imagem 2 %32 Gateway LT4004u Screen Replacement: passo 4, imagem 3 %32
    • Once the screen casing is removed, unscrew the 8 screws surrounding the screen and remove them from the laptop. All 8 screws should measure 4.0mm long.
    • There is a single screw in each red indicator and two screws in each orange indicator, totaling to the eight screws.
    Pergunte ao FixBot
    Comentar
  5. Gateway LT4004u Screen Replacement: passo 5, imagem 1 %32 Gateway LT4004u Screen Replacement: passo 5, imagem 2 %32 Gateway LT4004u Screen Replacement: passo 5, imagem 3 %32
    • Unplug the webcam connection from the top of the laptop screen backing.
    Pergunte ao FixBot
    Comentar
  6. Gateway LT4004u Screen Replacement: passo 6, imagem 1 %32 Gateway LT4004u Screen Replacement: passo 6, imagem 2 %32 Gateway LT4004u Screen Replacement: passo 6, imagem 3 %32
    • Flip the screen over so that it is lying on top of the keyboard.
    • Looking at the underside of the screen, remove the yellow tape and carefully remove the wires attaching the screen to the laptop.
    Pergunte ao FixBot
    Comentar
  7. Gateway LT4004u Screen Replacement: passo 7, imagem 1 %32
    • Remove the screen from the rest of the laptop.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
Clemson, Team 6-5, Benson Spring 2016 Membro de Clemson, Team 6-5, Benson Spring 2016
CLEM-BENSON-S16S6G5
4 Membros
Autoria de 16 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 8
Últimos 30 dias: 41
Ao todo: 957
