Ir para o conteúdo principal
Gateway ID49C07U Keyboard Replacement
O que você precisa
    1. Gateway ID49C07U Keyboard Replacement, Battery: passo 1, imagem 1 %32
      • Turn the laptop over so the bottom of the device is facing upwards with the hinge facing away from you.
      Pergunte ao FixBot
      Comentar
    2. Gateway ID49C07U Keyboard Replacement: passo 2, imagem 1 %32 Gateway ID49C07U Keyboard Replacement: passo 2, imagem 2 %32
      • Locate the switch on the top left of the laptop labeled with a padlock symbol.
      • Flip the switch in the direction of the unlocked padlock symbol.
      Pergunte ao FixBot
      Comentar
    3. Gateway ID49C07U Keyboard Replacement: passo 3, imagem 1 %32
      • Locate the switch that releases the battery and slide it to the right.
      Pergunte ao FixBot
      Comentar
    4. Gateway ID49C07U Keyboard Replacement: passo 4, imagem 1 %32
      • While holding the release switch to the right, pull the battery away from you.
      Pergunte ao FixBot
      Comentar
    1. Gateway ID49C07U Keyboard Replacement, Keyboard: passo 5, imagem 1 %32
      • Turn the laptop over and open
      Pergunte ao FixBot
      Comentar
    2. Gateway ID49C07U Keyboard Replacement: passo 6, imagem 1 %32 Gateway ID49C07U Keyboard Replacement: passo 6, imagem 2 %32 Gateway ID49C07U Keyboard Replacement: passo 6, imagem 3 %32
      • Use the small metal spudger to push in each of the clips on the keyboard
      Pergunte ao FixBot
      Comentar
    3. Gateway ID49C07U Keyboard Replacement: passo 7, imagem 1 %32 Gateway ID49C07U Keyboard Replacement: passo 7, imagem 2 %32 Gateway ID49C07U Keyboard Replacement: passo 7, imagem 3 %32
      • Continued
      Pergunte ao FixBot
      Comentar
    4. Gateway ID49C07U Keyboard Replacement: passo 8, imagem 1 %32 Gateway ID49C07U Keyboard Replacement: passo 8, imagem 2 %32
      • Use the small spudger to pick up the corner
      Pergunte ao FixBot
      Comentar
    5. Gateway ID49C07U Keyboard Replacement: passo 9, imagem 1 %32
      • Slide keyboard towards the screen
      Pergunte ao FixBot
      Comentar
    6. Gateway ID49C07U Keyboard Replacement: passo 10, imagem 1 %32 Gateway ID49C07U Keyboard Replacement: passo 10, imagem 2 %32
      • Use the small spudger to slide the cable lock up on both sides of the connector and slide the cable out
      Pergunte ao FixBot
      Comentar
Conclusão
Ryan Howlett
Membro desde: 03/06/17
273 Reputação
Autoria de 2 guias
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 19
Ao todo: 839
