Ir para o conteúdo principal
Gateway GWTC116-2BL Display Replacement
O que você precisa
  1. Gateway GWTC116-2BL Display Replacement, Back Panel: passo 1, imagem 1 %32
    • Ground yourself before disassembling and handling the computer.
    • Remove the ten 3.0 mm Phillips #00 screws from the back panel of the laptop.
    Pergunte ao FixBot
    Comentar
  2. Gateway GWTC116-2BL Display Replacement: passo 2, imagem 1 %32 Gateway GWTC116-2BL Display Replacement: passo 2, imagem 2 %32
    • Use the spudger to pry the back panel away from the body of the laptop.
    Pergunte ao FixBot
    Comentar
  3. Gateway GWTC116-2BL Display Replacement, Battery: passo 3, imagem 1 %32
    • Remove the five 3.0 mm Phillips #00 screws.
    Pergunte ao FixBot
    Comentar
  4. Gateway GWTC116-2BL Display Replacement: passo 4, imagem 1 %32 Gateway GWTC116-2BL Display Replacement: passo 4, imagem 2 %32
    • Using your fingers, flick open the battery connector bracket.
    • Remove the connector from bracket.
    Pergunte ao FixBot
    Comentar
  5. Gateway GWTC116-2BL Display Replacement: passo 5, imagem 1 %32
    • Pull up the battery to remove from the base.
    Pergunte ao FixBot
    Comentar
  6. Gateway GWTC116-2BL Display Replacement, Motherboard: passo 6, imagem 1 %32
    • Using your fingers, flick the cable connector bracket open.
    • Remove the cable from the connector.
    Pergunte ao FixBot
    Comentar
  7. Gateway GWTC116-2BL Display Replacement: passo 7, imagem 1 %32 Gateway GWTC116-2BL Display Replacement: passo 7, imagem 2 %32
    • Using your fingers, disconnect the black and white connector brackets underneath the gray cable.
    Pergunte ao FixBot
    Comentar
  8. Gateway GWTC116-2BL Display Replacement: passo 8, imagem 1 %32 Gateway GWTC116-2BL Display Replacement: passo 8, imagem 2 %32
    • Remove the four 3.0 mm Phillips #00 screws located on the motherboard casing.
    Pergunte ao FixBot
    Comentar
  9. Gateway GWTC116-2BL Display Replacement: passo 9, imagem 1 %32 Gateway GWTC116-2BL Display Replacement: passo 9, imagem 2 %32 Gateway GWTC116-2BL Display Replacement: passo 9, imagem 3 %32
    • Peel the yellow tape off of the casing.
    • Lift the casing off of the motherboard.
    Pergunte ao FixBot
    Comentar
  10. Gateway GWTC116-2BL Display Replacement: passo 10, imagem 1 %32 Gateway GWTC116-2BL Display Replacement: passo 10, imagem 2 %32
    • Peel off the yellow tape.
    • Remove four 3.0 mm Phillips #00 screws.
    Pergunte ao FixBot
    Comentar
  11. Gateway GWTC116-2BL Display Replacement: passo 11, imagem 1 %32 Gateway GWTC116-2BL Display Replacement: passo 11, imagem 2 %32
    • Peel off the black piece of tape covering the display cable.
    Pergunte ao FixBot
    Comentar
  12. Gateway GWTC116-2BL Display Replacement: passo 12, imagem 1 %32 Gateway GWTC116-2BL Display Replacement: passo 12, imagem 2 %32
    • Flick open the bracket securing the display cable and disconnect the cable from the motherboard.
    Pergunte ao FixBot
    Comentar
  13. Gateway GWTC116-2BL Display Replacement: passo 13, imagem 1 %32
    • Remove the motherboard from the device.
    Pergunte ao FixBot
    Comentar
  14. Gateway GWTC116-2BL Display Replacement, Display: passo 14, imagem 1 %32
    • Remove seven 3.0 mm Phillips #00 screws from the laptop.
    Pergunte ao FixBot
    Comentar
  15. Gateway GWTC116-2BL Display Replacement: passo 15, imagem 1 %32
    • Applying some force, use your hands to pry the display of the laptop away from the base.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Kailey Sousa
Membro desde: 03/22/24
522 Reputação
Autoria de 4 guias
Equipe
1Comentário do guia
Mon écran ne s'allume pas au démarrage. Que faire ?
Youssouf SAWADOGO - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 17
Últimos 30 dias: 57
Ao todo: 1,420
