Ir para o conteúdo principal
Garmin inReach Mini Motherboard Replacement
O que você precisa
  1. Garmin inReach Mini Motherboard Replacement, Nylon Strap: passo 1, imagem 1 %32
    • Place the device on a level surface with the back hard case facing up.
    Pergunte ao FixBot
    Comentar
  2. Garmin inReach Mini Motherboard Replacement: passo 2, imagem 1 %32 Garmin inReach Mini Motherboard Replacement: passo 2, imagem 2 %32 Garmin inReach Mini Motherboard Replacement: passo 2, imagem 3 %32
    • Use the T5 to remove the 1.9mm screw attached to the nylon strap.
    • Remove the nylon strap.
    Pergunte ao FixBot
    Comentar
  3. Garmin inReach Mini Motherboard Replacement, Back Case: passo 3, imagem 1 %32 Garmin inReach Mini Motherboard Replacement, Back Case: passo 3, imagem 2 %32 Garmin inReach Mini Motherboard Replacement, Back Case: passo 3, imagem 3 %32
    • Remove the five 1.8 mm screws located on the top, sides, and bottom corners of the backside of the device.
    Pergunte ao FixBot
    Comentar
  4. Garmin inReach Mini Motherboard Replacement: passo 4, imagem 1 %32 Garmin inReach Mini Motherboard Replacement: passo 4, imagem 2 %32 Garmin inReach Mini Motherboard Replacement: passo 4, imagem 3 %32
    • Lastly, lift the protective cap on the side of the device that states "SOS". Slowly pull it to the right in order to remove the back hard case.
    Pergunte ao FixBot
    Comentar
  5. Garmin inReach Mini Motherboard Replacement: passo 5, imagem 1 %32 Garmin inReach Mini Motherboard Replacement: passo 5, imagem 2 %32 Garmin inReach Mini Motherboard Replacement: passo 5, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Using the precision tweezers with the round tips, detach the battery connector from the motherboard.
    • Disconnecting the battery stops the flow of power into the motherboard. This is for your own safety.
    • If utilizing this guide as a prerequisite to replacing the motherboard, it is crucial not to damage the cable connecting the battery to the motherboard. When the new motherboard is introduced, it will need to be reconnected with that cable.
    Pergunte ao FixBot
    Comentar
  6. Garmin inReach Mini Motherboard Replacement, Battery: passo 6, imagem 1 %32 Garmin inReach Mini Motherboard Replacement, Battery: passo 6, imagem 2 %32 Garmin inReach Mini Motherboard Replacement, Battery: passo 6, imagem 3 %32
    • After removing the back hard case, users can access the battery on the inside of the back hard case.
    • Take the iFixit opening tool and insert it into the small crevices on each side of the battery. Once inserted, apply pressure downward in order to lift the battery up. Repeat on all 3 corners.
    Pergunte ao FixBot
    Comentar
  7. Garmin inReach Mini Motherboard Replacement: passo 7, imagem 1 %32 Garmin inReach Mini Motherboard Replacement: passo 7, imagem 2 %32
    • Create leverage by inserting the opening tool underneath the battery. Lift the battery up until it detaches from the case, then remove the battery entirely.
    Pergunte ao FixBot
    Comentar
  8. Garmin inReach Mini Motherboard Replacement: passo 8, imagem 1 %32
    • Then using the precision tweezers with the round tips, lightly pull the battery out from the case.
    • The battery is attached to the back hard case with an adhesive.
    • Dispose of the lithium ion battery in a safe manner in order to prevent electrical hazards. Keep the battery dry and cool.
    Pergunte ao FixBot
    Comentar
  9. Garmin inReach Mini Motherboard Replacement, Motherboard: passo 9, imagem 1 %32 Garmin inReach Mini Motherboard Replacement, Motherboard: passo 9, imagem 2 %32
    • Use the T5 screwdriver to remove each 5 mm screw.
    • Next, use the precision tweezers with the round tips to disconnect the black antenna wire from the motherboard.
    • Do not sever the black wire! This may render the device unusable, even when a new motherboard is introduced.
    Pergunte ao FixBot
    Comentar
  10. Garmin inReach Mini Motherboard Replacement: passo 10, imagem 1 %32 Garmin inReach Mini Motherboard Replacement: passo 10, imagem 2 %32
    • Using the precision tweezers with the round tips, gently pull up the thick red strip until it pops off of the motherboard.
    • Using the same tweezers, gently pull the thin red strip towards the end of the case in order to detach it from the motherboard.
    Pergunte ao FixBot
    Comentar
  11. Garmin inReach Mini Motherboard Replacement: passo 11, imagem 1 %32 Garmin inReach Mini Motherboard Replacement: passo 11, imagem 2 %32 Garmin inReach Mini Motherboard Replacement: passo 11, imagem 3 %32
    • Using the precision tweezers with the curved, pointy tips, squeeze both ends together, then insert them into the bottom left hole of the motherboard. Next, gently lift up the tweezers and pull out the motherboard.
    • Once you've pulled the motherboard halfway out, use the precision tweezers, or your fingers, to pull the motherboard out completely.
    • Be careful not to sever or damage any piece surrounding the motherboard, including the screen located beneath it! If any of the strips or cables are damaged, it may prevent the successful installation of a new motherboard.
    Pergunte ao FixBot
    Comentar
Conclusão
1Comentário do guia
Where can I buy parts for it?
TexanFrodo - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 6
Últimos 7 dias: 15
Últimos 30 dias: 81
Ao todo: 2,481
