Ir para o conteúdo principal
Garmin inReach Explorer Plus Motherboard Replacement
O que você precisa
  1. Garmin inReach Explorer Plus Motherboard Replacement, Battery: passo 1, imagem 1 %32
    • Using the TR6 Torx Security screwdriver, remove six 10 mm screws from the back cover of the device.
  2. Garmin inReach Explorer Plus Motherboard Replacement: passo 2, imagem 1 %32
    • Remove the back cover.
  3. Garmin inReach Explorer Plus Motherboard Replacement: passo 3, imagem 1 %32 Garmin inReach Explorer Plus Motherboard Replacement: passo 3, imagem 2 %32
    • Gently grasp the battery wire and disconnect it from the device.
    • Remove the battery from the device.
  4. Garmin inReach Explorer Plus Motherboard Replacement, Motherboard: passo 4, imagem 1 %32 Garmin inReach Explorer Plus Motherboard Replacement, Motherboard: passo 4, imagem 2 %32
    • Using the T5 Torx screwdriver, remove the six 6 mm screws from the motherboard.
  5. Garmin inReach Explorer Plus Motherboard Replacement: passo 5, imagem 1 %32 Garmin inReach Explorer Plus Motherboard Replacement: passo 5, imagem 2 %32
    • Disconnect the LCD screen from the motherboard by lifting on the flap with the nylon spudger.
    • The metal spudger should only be used for serious prying power. If used incorrectly, the metal spudger may damage the components of a device.
  6. Garmin inReach Explorer Plus Motherboard Replacement: passo 6, imagem 1 %32 Garmin inReach Explorer Plus Motherboard Replacement: passo 6, imagem 2 %32
    • Disconnect the antenna from the motherboard by lifting the wire with a nylon spudger.
  7. Garmin inReach Explorer Plus Motherboard Replacement: passo 7, imagem 1 %32 Garmin inReach Explorer Plus Motherboard Replacement: passo 7, imagem 2 %32 Garmin inReach Explorer Plus Motherboard Replacement: passo 7, imagem 3 %32
    • Gently lift the motherboard up and out of the device.
Conclusão
Sean Kelley
Membro desde: 09/28/21
387 Reputação
Autoria de 4 guias
Equipe
Clemson, Team 5-4, Hunter Fall 2021 Membro de Clemson, Team 5-4, Hunter Fall 2021
CLEM-HUNTER-F21S5G4
4 Membros
Autoria de 5 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 10
Ao todo: 274
