Ir para o conteúdo principal
Garmin StreetPilot c320 LCD Screen Replacement
O que você precisa
  1. Garmin StreetPilot c320 LCD Screen Replacement, Rear Case Assembly: passo 1, imagem 1 %32 Garmin StreetPilot c320 LCD Screen Replacement, Rear Case Assembly: passo 1, imagem 2 %32
    • Wedge a plastic opening tool in between the outer frame and the rear panel assembly.
    • Pry the outer frame off the perimeter of the rear panel assembly.
    • The cover will easily pop off.
    Pergunte ao FixBot
    Comentar
  2. Garmin StreetPilot c320 LCD Screen Replacement: passo 2, imagem 1 %32 Garmin StreetPilot c320 LCD Screen Replacement: passo 2, imagem 2 %32
    • Remove the four #00 Phillips screws securing the front case assembly to the rear case assembly.
    • Carefully lift, but do not completely separate, the front case assembly from the rear case assembly.
    • Be extremely cautious when separating both halves, as the rear case assembly is still attached to the front case assembly via a few connectors.
    Pergunte ao FixBot
    Comentar
  3. Garmin StreetPilot c320 LCD Screen Replacement: passo 3, imagem 1 %32
    • Gently pull the battery cable connector from its socket on the motherboard.
    • The second connector can remain attached to the motherboard, but be careful not to break the connector while handling both halves of the device.
    Pergunte ao FixBot
    Comentar
  4. Garmin StreetPilot c320 LCD Screen Replacement, LCD Screen: passo 4, imagem 1 %32
    • Remove the two Phillips #00 screws securing the motherboard to the front case assembly.
    Pergunte ao FixBot
    Comentar
  5. Garmin StreetPilot c320 LCD Screen Replacement: passo 5, imagem 1 %32
    • Slightly lift the motherboard upwards to reveal the LCD assembly.
    • Do not remove the motherboard yet, as it is stil attached to the LCD.
    Pergunte ao FixBot
    Comentar
  6. Garmin StreetPilot c320 LCD Screen Replacement: passo 6, imagem 1 %32
    • Use the edge of a plastic opening tool to flip up the retaining flap on the LCD ribbon cable ZIF socket.
    • Be sure you are prying up on the hinged retaining flap, not the socket itself.
    • Use the plastic opening tool to pull the LCD ribbon cable out of its socket.
    • Disconnect the right connector using the edge of a plastic opening tool.
    Pergunte ao FixBot
    Comentar
Conclusão
Equipe
Cal Poly, Team 11-19, Maness Winter 2012 Membro de Cal Poly, Team 11-19, Maness Winter 2012
CPSU-MANESS-W12S11G19
4 Membros
Autoria de 4 guias
1Comentário do guia
Geometry Dash World delivers short levels that are full of speed and excitement. Every jump must be timed carefully to avoid failure. The vibrant graphics and electronic music make the gameplay feel alive. It’s addictive from the very first level.
Ricky Graham - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 18
Ao todo: 1,828
