Ir para o conteúdo principal
Garmin Nuvi 56LMT Speaker Replacement
O que você precisa
  1. Garmin Nuvi 56LMT Speaker Replacement, Speaker: passo 1, imagem 1 %32
    • Power off you Garmin Nuvi before disassembling.
    • Use the T5 torx screwdriver to remove the four 11.0 mm screws.
  2. Garmin Nuvi 56LMT Speaker Replacement: passo 2, imagem 1 %32 Garmin Nuvi 56LMT Speaker Replacement: passo 2, imagem 2 %32
    • locate the crevice between the front and back panel.
    • Use the plastic opening tool to wedge the device open.
    • Carefully disconnect the ribbon from the ZIF connector.
  3. Garmin Nuvi 56LMT Speaker Replacement: passo 3, imagem 1 %32 Garmin Nuvi 56LMT Speaker Replacement: passo 3, imagem 2 %32
    • Locate the two 5.0 mm screws and use the T5 Torx screwdriver to remove them.
    • These screws are easily lost so keep track of them.
    • Once the screws are removed flip the motherboard over and locate the blue (+) and black (-) wires connected to the speaker.
  4. Garmin Nuvi 56LMT Speaker Replacement: passo 4, imagem 1 %32 Garmin Nuvi 56LMT Speaker Replacement: passo 4, imagem 2 %32
    • Use the crimping tool to cut the wires from the motherboard.
    • Use plastic opening tool or fingers to remove the speaker.
  5. Garmin Nuvi 56LMT Speaker Replacement: passo 5, imagem 1 %32
Conclusão
Dustin Saxon
Membro desde: 09/28/17
228 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team S3-G5, Nance Fall 2017 Membro de USF Tampa, Team S3-G5, Nance Fall 2017
USFT-NANCE-F17S3G5
Membros da 3
Autoria de 4 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 5
Duração total: 107
