Ir para o conteúdo principal
Garmin Nuvi 2599 Display Replacement
O que você precisa
  1. Garmin Nuvi 2599 Display Replacement, Display: passo 1, imagem 1 %32 Garmin Nuvi 2599 Display Replacement, Display: passo 1, imagem 2 %32
    • Use a T4 Torx screwdriver to remove the four 5.8 mm screws from the back of the device.
    Pergunte ao FixBot
    Comentar
  2. Garmin Nuvi 2599 Display Replacement: passo 2, imagem 1 %32 Garmin Nuvi 2599 Display Replacement: passo 2, imagem 2 %32
    • Insert an opening pick into the seam between the top and bottom case and slide it around the edge of the device to release the clips holding them together.
    • Insert an opening tool into the seam between the top and bottom casing, and gently pry them apart.
    • Avoid pulling them apart, as there are cables connecting the top and bottom case.
    Pergunte ao FixBot
    Comentar
  3. Garmin Nuvi 2599 Display Replacement: passo 3, imagem 1 %32 Garmin Nuvi 2599 Display Replacement: passo 3, imagem 2 %32
    • Use an opening tool or a clean fingernail to flip up the locking flap on the display cable—this is the unlocked position.
    • Use tweezers or your fingers to gently pull the ribbon cable out of its socket.
    • Remove the display assembly.
    Pergunte ao FixBot
    Comentar
Conclusão
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Bax Edwards
Membro desde: 09/25/25
757 Reputação
Autoria de 5 guias
Equipe
Texas Tech, Team 41-8, Allen Fall 2025 Membro de Texas Tech, Team 41-8, Allen Fall 2025
TTU-ALLEN-F25S41G8
3 Membros
Autoria de 5 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 21
Ao todo: 134
