Ir para o conteúdo principal
Garmin Nuvi 200 Speaker Replacement
O que você precisa
  1. Garmin Nuvi 200 Speaker Replacement, Rear Casing: passo 1, imagem 1 %32 Garmin Nuvi 200 Speaker Replacement, Rear Casing: passo 1, imagem 2 %32
    • Peel off the sticker from the bottom of the device to reveal two screws.
  2. Garmin Nuvi 200 Speaker Replacement: passo 2, imagem 1 %32
    • Remove two T5 Torx screws.
  3. Garmin Nuvi 200 Speaker Replacement: passo 3, imagem 1 %32 Garmin Nuvi 200 Speaker Replacement: passo 3, imagem 2 %32
    • Insert a plastic opening tool in the gap between the front and rear casing.
    • Carefully work the tool around the gap, separating the two halves of the case.
    • Keep the power switch in place while removing the rear case.
  4. Garmin Nuvi 200 Speaker Replacement, Speaker: passo 4, imagem 1 %32
    • Unscrew the two screws on opposite sides of the speaker using the #00 Phillips screwdriver.
    there is no use showing how to replace a speaker in nuvi if we cant find any
    seems like a god dam mistery
    Jean Michel Tche - Responder
  5. Garmin Nuvi 200 Speaker Replacement: passo 5, imagem 1 %32
    • Pull the cable out to detach the speaker from the logic board.
  6. Garmin Nuvi 200 Speaker Replacement: passo 6, imagem 1 %32 Garmin Nuvi 200 Speaker Replacement: passo 6, imagem 2 %32 Garmin Nuvi 200 Speaker Replacement: passo 6, imagem 3 %32
    • Wedge the iPod opener into the space between the speaker and the case.
    • Apply pressure to pry the speaker away from the case.
Conclusão
3 outras pessoas executaram este guia.
Anjelica
Membro desde: 04/11/10
564 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 25-90, Amido Spring 2010 Membro de Cal Poly, Team 25-90, Amido Spring 2010
CPSU-AMIDO-S10S25G90
4 Membros
Autoria de 9 guias
2Comentários do guia
just a note i had a problem with the speaker in my nuvi 200 an upon opening up found speaker plug had come loose i guess from being dropped a few times pushed plug in an works fine please check all connections before replacing your speaker saved me $$ thanks for a great site everyone...
randaleholland - Responder
Where can you buy replacement speakers for the Garmin units?
Brat Fry - Responder
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 7
Ao todo: 7,130
