Ir para o conteúdo principal
Garmin GPSmap 60CSx Screen Replacement
O que você precisa
  1. Garmin GPSmap 60CSx Screen Replacement, Back Cover and AA Batteries: passo 1, imagem 1 %32
    • Lift and twist the battery cover release 90 degrees counterclockwise on the back of the device.
    Pergunte ao FixBot
    Comentar
  2. Garmin GPSmap 60CSx Screen Replacement: passo 2, imagem 1 %32
    • Lift battery release up to remove battery cover.
    Pergunte ao FixBot
    Comentar
  3. Garmin GPSmap 60CSx Screen Replacement: passo 3, imagem 1 %32 Garmin GPSmap 60CSx Screen Replacement: passo 3, imagem 2 %32
    • Pull AA batteries out.
    Pergunte ao FixBot
    Comentar
  4. Garmin GPSmap 60CSx Screen Replacement, Screen: passo 4, imagem 1 %32 Garmin GPSmap 60CSx Screen Replacement, Screen: passo 4, imagem 2 %32
    • Remove the six 10 mm screws on the back of the device with a Phillips #0 Screwdriver.
    • Flip the back panel over to view the green electronics board (the PCB) and the PCB cover.
    • Remove the black, yellow, blue, and red wires connected to the PCB with light force.
    Pergunte ao FixBot
    Comentar
  5. Garmin GPSmap 60CSx Screen Replacement: passo 5, imagem 1 %32
    • Take the spudger and place it in the bottom right corner of the black PCB cover.
    • Use the spudger to pry the corner out. This will need to be done to all four corners of the PCB cover.
    • It is best to do remove the bottom corners first.
    • Pull the PCB cover out of the GPSMap 60CSx.
    Pergunte ao FixBot
    Comentar
  6. Garmin GPSmap 60CSx Screen Replacement: passo 6, imagem 1 %32 Garmin GPSmap 60CSx Screen Replacement: passo 6, imagem 2 %32
    • Carefully use the spudger to lift the PCB a few centimeters.
    • Pull the PCB towards the bottom of the GPSMap 60CSx.
    • This will pull the other components out of the GPSMap 60CSx like the antenna and the screen.
    Pergunte ao FixBot
    Comentar
  7. Garmin GPSmap 60CSx Screen Replacement: passo 7, imagem 1 %32 Garmin GPSmap 60CSx Screen Replacement: passo 7, imagem 2 %32 Garmin GPSmap 60CSx Screen Replacement: passo 7, imagem 3 %32
    • Apply light pressure to the four white tabs that are holding the screen in place.
    • The screen will now come off the PCB.
    Pergunte ao FixBot
    Comentar
  8. Garmin GPSmap 60CSx Screen Replacement: passo 8, imagem 1 %32
    • Turn the PCB over so the screen connector is facing you.
    • Move the screen out of the way for access to the screen connector.
    Pergunte ao FixBot
    Comentar
  9. Garmin GPSmap 60CSx Screen Replacement: passo 9, imagem 1 %32 Garmin GPSmap 60CSx Screen Replacement: passo 9, imagem 2 %32 Garmin GPSmap 60CSx Screen Replacement: passo 9, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Use tweezers to pull the two white pins on the connector forward.
    Pergunte ao FixBot
    Comentar
  10. Garmin GPSmap 60CSx Screen Replacement: passo 10, imagem 1 %32
    • Remove the screen ribbon connector and screen.
    Pergunte ao FixBot
    Comentar
Conclusão
5 outras pessoas executaram este guia.
2Comentários do guia
i have a 60csx and the battery bounces the liquid, can help me?
salvador2707 - Responder Compartilhar
Thank you for these step by step detailed instructions.
jlciscorp - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 11
Últimos 30 dias: 43
Ao todo: 5,700
