Ir para o conteúdo principal
Garmin GPSmap 60CSx Battery Terminal Replacement
O que você precisa
  1. Garmin GPSmap 60CSx Battery Terminal Replacement, Back Cover and AA Batteries: passo 1, imagem 1 %32
    • Lift and twist the battery cover release 90 degrees counterclockwise on the back of the device.
    Pergunte ao FixBot
    Comentar
  2. Garmin GPSmap 60CSx Battery Terminal Replacement: passo 2, imagem 1 %32
    • Lift battery release up to remove battery cover.
    Pergunte ao FixBot
    Comentar
  3. Garmin GPSmap 60CSx Battery Terminal Replacement: passo 3, imagem 1 %32 Garmin GPSmap 60CSx Battery Terminal Replacement: passo 3, imagem 2 %32
    • Pull AA batteries out.
    Pergunte ao FixBot
    Comentar
  4. Garmin GPSmap 60CSx Battery Terminal Replacement, Battery Terminals: passo 4, imagem 1 %32
    • Remove the six 10 mm screws on the back of the device with a Phillips #0 Screwdriver.
    Pergunte ao FixBot
    Comentar
  5. Garmin GPSmap 60CSx Battery Terminal Replacement: passo 5, imagem 1 %32 Garmin GPSmap 60CSx Battery Terminal Replacement: passo 5, imagem 2 %32
    • Place spudger behind the lower right battery terminal.
    • Push spudger behind the battery terminal to pop it out of place.
    • Now do the same on the bottom left side.
    Pergunte ao FixBot
    Comentar
  6. Garmin GPSmap 60CSx Battery Terminal Replacement: passo 6, imagem 1 %32 Garmin GPSmap 60CSx Battery Terminal Replacement: passo 6, imagem 2 %32
    • Grab the now loose battery terminals and pull them from the GPSMap 60CSx.
    Pergunte ao FixBot
    Comentar
  7. Garmin GPSmap 60CSx Battery Terminal Replacement: passo 7, imagem 1 %32 Garmin GPSmap 60CSx Battery Terminal Replacement: passo 7, imagem 2 %32
    • Flip the back panel over to expose the backs of the top battery terminals.
    • Use a metal spudger to remove the glue that covers them.
    Pergunte ao FixBot
    Comentar
  8. Garmin GPSmap 60CSx Battery Terminal Replacement: passo 8, imagem 1 %32 Garmin GPSmap 60CSx Battery Terminal Replacement: passo 8, imagem 2 %32
    • Flip the back panel back over to view the battery compartment.
    • Place the spudger behind one of the top remaining battery terminals.
    • Push the spudger down and pop the battery terminal out of place.
    • Repeat with the remaining battery terminal.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
10Comentários do guia
What did you use to replace the contacts?
Austin Chopra - Responder Compartilhar
Where can I buy replacement terminals?
Mitch - Responder Compartilhar
Mitch, Garmin just told me they do no sell replacement terminals for this 60CSx. Were you able to find any?
Ernie Sammons - Responder Compartilhar
Where can I find replacement battery terminals for a
Garmin 60CS4?
Sonny Pierce - Responder Compartilhar
Where can I find replacement battery terminals for a Garmin Map76CS?
Paul - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 18
Últimos 30 dias: 99
Ao todo: 12,078
