Ir para o conteúdo principal
Garmin GPS V Logic Board Replacement
O que você precisa
  1. Garmin GPS V Logic Board Replacement, Logic Board: passo 1, imagem 1 %32 Garmin GPS V Logic Board Replacement, Logic Board: passo 1, imagem 2 %32 Garmin GPS V Logic Board Replacement, Logic Board: passo 1, imagem 3 %32
    • Orient the GPS V backside up.
    • With a #0 Philips screwdriver, remove six M2x0.4 black screws on the back of the unit.
    Pergunte ao FixBot
    Comentar
  2. Garmin GPS V Logic Board Replacement: passo 2, imagem 1 %32 Garmin GPS V Logic Board Replacement: passo 2, imagem 2 %32
    • With the spudger, gently pry the back plate off the unit starting at the corners.
    • Open the back plate about 35°, use the antenna side act like a hinge.
    • Do NOT remove the back plate all the way, there are cables connected to it.
    Pergunte ao FixBot
    Comentar
  3. Garmin GPS V Logic Board Replacement: passo 3, imagem 1 %32 Garmin GPS V Logic Board Replacement: passo 3, imagem 2 %32
    • Locate the white 8-pin connector on the logic board and disconnect it.
    • Open the device all the way, making sure to not disconnect the brown antenna wire.
    Pergunte ao FixBot
    Comentar
  4. Garmin GPS V Logic Board Replacement: passo 4, imagem 1 %32 Garmin GPS V Logic Board Replacement: passo 4, imagem 2 %32
    • With a #1 Philips screwdriver, remove the silver M2x0.4 screw on the logic board near the brown wire.
    • You may need to rotate the device to get better access to the screw.
    Pergunte ao FixBot
    Comentar
  5. Garmin GPS V Logic Board Replacement: passo 5, imagem 1 %32 Garmin GPS V Logic Board Replacement: passo 5, imagem 2 %32 Garmin GPS V Logic Board Replacement: passo 5, imagem 3 %32
    • Locate the ribbon connector on the logic board.
    • With the spudger, gently apply pressure to both sides of the brown connector lock until it pushes out.
    • With the spudger, gently work the ribbon cable out of the connector until it is free.
    Pergunte ao FixBot
    Comentar
  6. Garmin GPS V Logic Board Replacement: passo 6, imagem 1 %32 Garmin GPS V Logic Board Replacement: passo 6, imagem 2 %32
    • With the spudger, gently pry out the logic board.
    • Be careful to not disconnect the brown antenna wire as you remove the logic board.
    Pergunte ao FixBot
    Comentar
  7. Garmin GPS V Logic Board Replacement: passo 7, imagem 1 %32
    • Locate the brown wire connection on the logic board.
    • Carefully apply heat with the soldering iron while gently pulling on the brown wire.
    • It may take some time to heat the flux up before the wire can be pulled out.
    • Pull brown wire free of the logic board.
    Pergunte ao FixBot
    Comentar
Conclusão
Connor
Membro desde: 01/23/12
194 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 3-25, Amido Winter 2012 Membro de Cal Poly, Team 3-25, Amido Winter 2012
CPSU-AMIDO-W12S3G25
4 Membros
Autoria de 4 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 27
Ao todo: 6,029
