Ir para o conteúdo principal
Garmin Forerunner 405 Button Replacement
O que você precisa
    1. Garmin Forerunner 405 Button Replacement, Unscrew backing: passo 1, imagem 1 %32
      • Unscrew the four 6.35 mm Torx T5 screws securing the backing of the watch.
      Pergunte ao FixBot
      Comentar
    2. Garmin Forerunner 405 Button Replacement, Separate Component: passo 2, imagem 1 %32
      • Pull the backing off the watch.
      Pergunte ao FixBot
      Comentar
    3. Garmin Forerunner 405 Button Replacement, Separate: passo 3, imagem 1 %32
      • Pull the battery wires out from the motherboard slowly.
      Pergunte ao FixBot
      Comentar
    4. Garmin Forerunner 405 Button Replacement, Unscrew: passo 4, imagem 1 %32
      • Unscrew one 4 mm philips screw that attaches the motherboard using a PH000 screwdriver.
      • Lift the motherboard out of the watch.
      Pergunte ao FixBot
      Comentar
    5. Garmin Forerunner 405 Button Replacement, Pull apart: passo 5, imagem 1 %32 Garmin Forerunner 405 Button Replacement, Pull apart: passo 5, imagem 2 %32
      Ferramenta utilizada neste passo:
      • Push button in and pinch silver clip with tweezers.
      • Pull silver clip off the pin it is on.
      • Pull out button and replace.
      Pergunte ao FixBot
      Comentar
Conclusão
Kyle Kiwczak
Membro desde: 09/11/14
328 Reputação
Autoria de 3 guias
Equipe
2Comentários do guia
Where to find repair button for FR60? Can it be 3d printed? Garmin asks too much out-of-warranty
vasiljevicic - Responder Compartilhar
I took mine apart to find that the jammed button was actually bent. Using two pairs of needle-nose pliers, I was able to straighten it and re-use it. The watch works great now.
keithnbrauneckermil - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 11
Ao todo: 4,102
