Ir para o conteúdo principal
Garmin Fenix 3 Battery Replacement
O que você precisa
    1. Garmin Fenix 3 Battery Replacement, Display Assembly: passo 1, imagem 1 %32 Garmin Fenix 3 Battery Replacement, Display Assembly: passo 1, imagem 2 %32
      • Use a T6 screwdriver to remove the five 1.7 mm screws from the watch face.
      Pergunte ao FixBot
      Comentar
    2. Garmin Fenix 3 Battery Replacement: passo 2, imagem 1 %32
      • Carefully lift the face off the watch base.
      • Do not yank the face. A ribbon connector connects the face and the motherboard, and yanking could result in damage to the motherboard or ribbon.
      Pergunte ao FixBot
      Comentar
    3. Garmin Fenix 3 Battery Replacement: passo 3, imagem 1 %32
      • Use a spudger to lift up and free the screen ribbon cable's press-fit connector from the motherboard.
      Pergunte ao FixBot
      Comentar
    4. Garmin Fenix 3 Battery Replacement: passo 4, imagem 1 %32
      • Set the watch face aside.
      Pergunte ao FixBot
      Comentar
    1. Garmin Fenix 3 Battery Replacement, GPS Antenna: passo 5, imagem 1 %32
      • Locate the antenna, which is located on the motherboard.
      Pergunte ao FixBot
      Comentar
    2. Garmin Fenix 3 Battery Replacement: passo 6, imagem 1 %32
      • Carefully remove the antenna, and set it aside.
      Pergunte ao FixBot
      Comentar
    1. Garmin Fenix 3 Battery Replacement, Battery: passo 7, imagem 1 %32 Garmin Fenix 3 Battery Replacement, Battery: passo 7, imagem 2 %32 Garmin Fenix 3 Battery Replacement, Battery: passo 7, imagem 3 %32
      Ferramenta utilizada neste passo:
      • Use a T5 screwdriver to remove the two silver 1.4 mm screws from the motherboard.
      • To avoid losing or dropping the screws once they are loose, use tweezers to extract them.
      Pergunte ao FixBot
      Comentar
    2. Garmin Fenix 3 Battery Replacement: passo 8, imagem 1 %32 Garmin Fenix 3 Battery Replacement: passo 8, imagem 2 %32
      • Lift the watch and turn it over one hand. The motherboard should fall out easily.
      • When reinserting your motherboard, slide it in instead of pressing it. The motherboard must go beneath a lip at the base of the watch body.
      Pergunte ao FixBot
      Comentar
    3. Garmin Fenix 3 Battery Replacement: passo 9, imagem 1 %32
      • Using the spludger, separate the battery from the motherboard, which are both held together with a mild adhesive. Note that the battery connector lifts upward away from the circuit board by simply lifting the wires up should pop the connector.
      • When re-seating the new battery connector make sure the connector is seated home fully or it will not work and the the watch will show "100%" when on the charger but will not start.
      Pergunte ao FixBot
      Comentar
Conclusão
22 outras pessoas executaram este guia.
37Comentários do guia
Ruined my watch… The battery connection socket ripped off with the battery connector…
I have taken apart phones and laptops in the past without issue, so I am not inexperienced by any means. I was as careful as possible.
John Smith - Responder Compartilhar
Sounds like it may have had a factory defect. I did the same fix and it worked fine, just like any other computer or phone.
Hamilton Cooper - Responder Compartilhar
Excellent guide - thanks! My Fenix3 wasn't charging any more so following your guide I replaced the ‘dead’ battery with a new one with ease. However, when reassembled, the new battery worked but would not charge. I took it apart again, and found slight corrosion or gunk on the motherboard terminals where they contact the inner side of the charging pins. After a good clean with meths and a cotton bud I popped the original battery back in, reassembled it, and hey presto! it started charging! Very happy!
Nick Coldham - Responder Compartilhar
I appreciate the guide as my Fenix 3 after 6 years of owning it could barely make it 24 hours without charging it.
The only thing I’d add to the guide is that you can reuse the adhesive from the existing battery as it’s only double-sided tape. Other than, it went flawless!
Roy J. Villarreal III - Responder Compartilhar
Thanks for this. Just did it successfully. A quick note, when you are separating the battery from the motherboard, it pulls up/perpendicular to the device and not parallel to it as I had initially thought. Luckily I did not break the battery connector to the motherboard. When I put it back in I needed to push it towards the motherboard to properly seat it. Look closely to make sure no part of the connector is sticking up, even a hair or it will not work.
Michael Reid - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 10
Últimos 7 dias: 63
Últimos 30 dias: 295
Ao todo: 31,742
