Introdução
We will be replacing the battery in the Garmin Fenix 2 watch. You should have a Torx T9 screwdriver on hand and a nylon spudger.
O que você precisa
Use a Torx T9 screwdriver to remove these four .8mm screws and seperate the housing.
11 outras pessoas executaram este guia.
7Comentários do guia
can you tell us exactly which battery should be used? Thanks in advance!
Look for: RouteJD Inc PD3032 3.7V 200mAh - I found one on Ebay
Are you certain that's the proper battery? Garmin's website says the Fenix 2 has a 500mAh capacity.
Garmin's website says the battery is a 500mAh capacity. Are you certain that is the correct one?
After some research on eBay the correct battery size should be PD3555 3.7V which is 500mAh.
