Ir para o conteúdo principal
Garmin DriveSmart 55 EX Screen Replacement
O que você precisa
  1. Garmin DriveSmart 55 EX Screen Replacement, Screen: passo 1, imagem 1 %32 Garmin DriveSmart 55 EX Screen Replacement, Screen: passo 1, imagem 2 %32 Garmin DriveSmart 55 EX Screen Replacement, Screen: passo 1, imagem 3 %32
    • Use a T5 Torx screwdriver to remove the four 4.2 mm black screws from the back case.
    • Insert the plastic opening tool into the gap between the screen and case, and release the clips along the edges of the device.
    • Use opening picks along the perimeter to keep them separated until you can remove the screen.
    Pergunte ao FixBot
    Comentar
  2. Garmin DriveSmart 55 EX Screen Replacement: passo 2, imagem 1 %32 Garmin DriveSmart 55 EX Screen Replacement: passo 2, imagem 2 %32 Garmin DriveSmart 55 EX Screen Replacement: passo 2, imagem 3 %32
    • Gently separate the screen from the case and place the device flat on the surface.
    • Avoid pulling on the screen too forcefully, as the display ribbon cable is still connected to the motherboard.
    • Use a T5 Torx screwdriver to remove the four 3.8 mm silver screws from the motherboard.
    • Avoid scratching the motherboard when using the screwdriver, as this can damage the device.
    • Gently pry the motherboard up using the plastic opening tool.
    Pergunte ao FixBot
    Comentar
  3. Garmin DriveSmart 55 EX Screen Replacement: passo 3, imagem 1 %32 Garmin DriveSmart 55 EX Screen Replacement: passo 3, imagem 2 %32
    • Use your fingers or tweezers to disconnect the battery connector on the underside of the motherboard.
    • Avoid pulling on the cables.
    Pergunte ao FixBot
    Comentar
  4. Garmin DriveSmart 55 EX Screen Replacement: passo 4, imagem 1 %32 Garmin DriveSmart 55 EX Screen Replacement: passo 4, imagem 2 %32 Garmin DriveSmart 55 EX Screen Replacement: passo 4, imagem 3 %32
    • Use a spudger or a clean fingernail to flip up the locking flap on the ZIF connector.
    • Use the widest tool possible to avoid damaging the delicate hinge pins.
    • Use tweezers to gently pull the gold ribbon cable from the socket on the motherboard.
    • Be careful when removing the ribbon cable because it is thin and can tear easily.
    Pergunte ao FixBot
    Comentar
  5. Garmin DriveSmart 55 EX Screen Replacement: passo 5, imagem 1 %32 Garmin DriveSmart 55 EX Screen Replacement: passo 5, imagem 2 %32
    • Insert a spudger or plastic opening tool into the gap between the screen and display frame.
    • Once a corner begins to lift, slowly slide the tool around the edges to release the clips securing them.
    • The screen is glass and if you use too much force it can shatter and crack the screen.
    • Separate the screen from the device.
    Pergunte ao FixBot
    Comentar
Conclusão
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 23
Ao todo: 97
