Ir para o conteúdo principal
Garmin Drive 60LM Motherboard Replacement
O que você precisa
  1. Garmin Drive 60LM Motherboard Replacement, Motherboard: passo 1, imagem 1 %32 Garmin Drive 60LM Motherboard Replacement, Motherboard: passo 1, imagem 2 %32
    • Using the T4 Torx screwdriver, unscrew all four of the screws (1/4 inch, 6.35 mm) from the back panel of your device.
    Pergunte ao FixBot
    Comentar
  2. Garmin Drive 60LM Motherboard Replacement: passo 2, imagem 1 %32 Garmin Drive 60LM Motherboard Replacement: passo 2, imagem 2 %32 Garmin Drive 60LM Motherboard Replacement: passo 2, imagem 3 %32
    • Remove the back panel using the metal spudger tool.
    • The metal spudger tool can cause damage to internal components.
    • Flip the device over with the screen facing upward and open the device.
    Pergunte ao FixBot
    Comentar
  3. Garmin Drive 60LM Motherboard Replacement: passo 3, imagem 1 %32 Garmin Drive 60LM Motherboard Replacement: passo 3, imagem 2 %32 Garmin Drive 60LM Motherboard Replacement: passo 3, imagem 3 %32
    • Use a plastic spudger to flip up the white clamp holding the orange ribbon in place to the motherboard.
    • Lift the screen and orange ribbon away from the motherboard.
    • The metal spudger pictured is not ESD safe. Use a plastic spudger instead.
    Pergunte ao FixBot
    Comentar
  4. Garmin Drive 60LM Motherboard Replacement: passo 4, imagem 1 %32 Garmin Drive 60LM Motherboard Replacement: passo 4, imagem 2 %32
    • Using the T4 Torx screwdriver, unscrew the four screws (1/2 cm, 5mm) from the motherboard.
    • Then, lift the motherboard out of its position.
    Pergunte ao FixBot
    Comentar
  5. Garmin Drive 60LM Motherboard Replacement: passo 5, imagem 1 %32 Garmin Drive 60LM Motherboard Replacement: passo 5, imagem 2 %32
    • Flip the motherboard over towards the right.
    • Then, carefully disconnect the two sets of wires that are connected to the battery and the speaker using your fingers.
    • Remove the motherboard.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Andy Flores
Membro desde: 01/30/17
247 Reputação
Autoria de 2 guias
Equipe
Baylor, Team 3-3, Whitney Spring 2017 Membro de Baylor, Team 3-3, Whitney Spring 2017
BU-WHITNEY-S17S3G3
4 Membros
Autoria de 3 guias
2Comentários do guia
Bonjour, ou trouver la carte mère ?
Hello, where can I find the motherboard?
th.lamouroux - Responder Compartilhar
i lost the screws while replacing the batterry. where do ifind the screws
Carolyn Mock - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 9
Últimos 30 dias: 37
Ao todo: 1,909
