Ir para o conteúdo principal
Garmin Approach S2 Battery Replacement
O que você precisa
  1. Garmin Approach S2 Battery Replacement, Back Cover: passo 1, imagem 1 %32 Garmin Approach S2 Battery Replacement, Back Cover: passo 1, imagem 2 %32
    • Remove the six T5 Torx 6.32mm screws securing the back cover to the watch.
    Pergunte ao FixBot
    Comentar
  2. Garmin Approach S2 Battery Replacement: passo 2, imagem 1 %32
    • Remove the back cover carefully.
    • Even after the screws have been removed, the back cover can still be quite difficult to take off. Moderate to extensive prying may be required. Be gentle, but firm.
    Pergunte ao FixBot
    Comentar
  3. Garmin Approach S2 Battery Replacement, Battery: passo 3, imagem 1 %32
    • On the back cover use a plastic opening tool to remove the green tape retaining the battery.
    Pergunte ao FixBot
    Comentar
  4. Garmin Approach S2 Battery Replacement: passo 4, imagem 1 %32 Garmin Approach S2 Battery Replacement: passo 4, imagem 2 %32
    • Remove the green tape shrouding the battery connector.
    Pergunte ao FixBot
    Comentar
  5. Garmin Approach S2 Battery Replacement: passo 5, imagem 1 %32 Garmin Approach S2 Battery Replacement: passo 5, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Use the ESD safe tweezers to push the connector and metal shroud out from the back of the connector.
    • Remove the third and fourth wires from the right of the connector (as seen when looking from the angle in the photo). They should be red and black respectively.
    • DO NOT attempt to pull the wire from the connector, it will pull the wire from the metal shroud shown in the red box, which needs to be preserved for the connection to be successful.
    Pergunte ao FixBot
    Comentar
  6. Garmin Approach S2 Battery Replacement: passo 6, imagem 1 %32
    • Use the ESD safe tweezers to break the adhesive between the back cover and the battery.
    • Remove the battery.
    Pergunte ao FixBot
    Comentar
  7. Garmin Approach S2 Battery Replacement: passo 7, imagem 1 %32
    • Remove the green tape on the back of the battery, it can be reused later.
    Pergunte ao FixBot
    Comentar
Conclusão
6 outras pessoas executaram este guia.
Emily Kovacs
Membro desde: 03/21/18
259 Reputação
Autoria de 1 guia
Equipe
IUPUI, Team S4-G1, Baechle Spring 2018 Membro de IUPUI, Team S4-G1, Baechle Spring 2018
IUPUI-BAECHLE-S18S4G1
3 Membros
Autoria de 5 guias
8Comentários do guia
If anyone is looking for the replacement battery for the Approach S2 it can be found here:
Replacement Battery for Garmin Approach S2
It also included the T5 Torx and Opening Tools that are needed.
michaelf33707 - Responder Compartilhar
Step 6 shows 2 red wires each with a free end. One of these red wires has the non free end connected to the charging circuit terminal but there is no mention in Step 6 of disconnecting this wire or where the free end is connected to.
Paul Stevenson - Responder Compartilhar
This is a great tutorial for the S2. In my case I accidentally dropped one metal shroud (referred to in Step 5). I scoured the area on my hands and knees to no avail. Can you direct me to where I might obtain this part?or perhaps the entire connector? Thank you….
Brian Mahoney - Responder Compartilhar
Hi, Where the !&&* Can I buy a Replacement Battery for The Garmin S2 Golf watch.????.
Gregory John Wickenden - Responder Compartilhar
Gregory, I got my replacement via Amazon (UK). Battery came from Germany in about 1 week. Not cheap, but a lot cheaper than a new watch.
john.joice - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 53
Últimos 30 dias: 254
Ao todo: 46,348
