Ir para o conteúdo principal
Garbage Disposal Replacement
  1. Garbage Disposal Replacement, Garbage Disposal: passo 1, imagem 1 %32
    • Before installing your garbage disposal, make sure both your pipes and garbage disposal mount (pictured at the top) are aligned correctly to support your model.
    Pergunte ao FixBot
    Comentar
  2. Garbage Disposal Replacement: passo 2, imagem 1 %32
    • Attach your garbage disposal to the mount (circled) that is attached to the sink hole.
    Pergunte ao FixBot
    Comentar
  3. Garbage Disposal Replacement: passo 3, imagem 1 %32
    • Connect the silver mounting hardware attached to the top of the garbage disposal by turning it clockwise.
    • Mount disposal to the sink using one hand to lift it and the other to attach to the silver mounting hardware while making sure to match the grooves of your disposal into the mount. The disposal should now be all in one piece.
    Pergunte ao FixBot
    Comentar
  4. Garbage Disposal Replacement: passo 4, imagem 1 %32 Garbage Disposal Replacement: passo 4, imagem 2 %32 Garbage Disposal Replacement: passo 4, imagem 3 %32
    • After mounting the disposal in place, align the black disposal pipe with the white PVC pipe connected to the sink.
    Pergunte ao FixBot
    Comentar
  5. Garbage Disposal Replacement: passo 5, imagem 1 %32
    • Connect the dishwasher drain tube to the garbage disposable.
    Pergunte ao FixBot
    Comentar
  6. Garbage Disposal Replacement: passo 6, imagem 1 %32
    • Once everything is in place, tighten all of your tube rings to ensure no leakage occurs.
    Pergunte ao FixBot
    Comentar
  7. Garbage Disposal Replacement: passo 7, imagem 1 %32
    • Install and plug electrical wire into the correct power source. Test your disposal switch and check for any signs of leakage.
    Pergunte ao FixBot
    Comentar
Conclusão
Be sure to test your garbage disposal before sending any waste down the drain. Happy disposing!
5 outras pessoas executaram este guia.
1Comentário do guia
There is a tiny hose that attaches to an air compressor. It keeps falling off.
Nancy Raza - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 8
Últimos 7 dias: 61
Últimos 30 dias: 249
Ao todo: 7,098
