Ir para o conteúdo principal
GameSir Cyclone 2 LED Replacement
O que você precisa
    1. GameSir Cyclone 2 LED Replacement, Face Plate: passo 1, imagem 1 %32 GameSir Cyclone 2 LED Replacement, Face Plate: passo 1, imagem 2 %32 GameSir Cyclone 2 LED Replacement, Face Plate: passo 1, imagem 3 %32
      • Flip the controller around so the back part is facing you.
      • Use a T6 Torx screwdriver to remove seven screws from the back of the controller.
      • One of the screws is hidden under the sticker. Use a pair of tweezers to lift the sticker and reveal the screw.
      Pergunte ao FixBot
      Comentar
    2. GameSir Cyclone 2 LED Replacement: passo 2, imagem 1 %32
      • The screws holding the face plate are of two different lengths:
      • The two longer screws belong to the two top screw sockets on the controller.
      • The five shorter screws belong in the five bottom screw sockets, two per handle, and on in the center of on the controller.
      Pergunte ao FixBot
      Comentar
    3. GameSir Cyclone 2 LED Replacement: passo 3, imagem 1 %32 GameSir Cyclone 2 LED Replacement: passo 3, imagem 2 %32
      • Face the controller toward you.
      • Gently lift the face plate off the controller.
      • The d-pad and action buttons will become loose once the face plate is lifted.
      Pergunte ao FixBot
      Comentar
    1. GameSir Cyclone 2 LED Replacement, Joystick Covers: passo 4, imagem 1 %32 GameSir Cyclone 2 LED Replacement, Joystick Covers: passo 4, imagem 2 %32 GameSir Cyclone 2 LED Replacement, Joystick Covers: passo 4, imagem 3 %32
      • Pull both joystick covers straight up to remove them from the controller.
      Pergunte ao FixBot
      Comentar
    1. GameSir Cyclone 2 LED Replacement, Left and Right Bumpers and Triggers: passo 5, imagem 1 %32
      • Note the bumpers and triggers on the controller.
      Pergunte ao FixBot
      Comentar
    2. GameSir Cyclone 2 LED Replacement: passo 6, imagem 1 %32
      • Use a Phillips #00 screwdriver to remove two screws on either side of the power button.
      • Remove the assembly that includes the power button and the top bumper buttons.
      Pergunte ao FixBot
      Comentar
    3. GameSir Cyclone 2 LED Replacement: passo 7, imagem 1 %32
      • Remove the bumpers and triggers from the controller.
      Pergunte ao FixBot
      Comentar
    1. GameSir Cyclone 2 LED Replacement, LED: passo 8, imagem 1 %32
      • Locate the two black boxes towards the bottom of the controller.
      • Remove these two boxes by pulling them away from the controller. They should snap right off.
      Pergunte ao FixBot
      Comentar
    2. GameSir Cyclone 2 LED Replacement: passo 9, imagem 1 %32
      • Locate the LED diffusers on either side of the controller face. They are clear, cylindrical strips that help spread light from the LED beneath the black boxes removed in the previous step.
      • Lift the upper ends of each LED diffuser and remove them.
      Pergunte ao FixBot
      Comentar
Conclusão
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Uma outra pessoa concluiu este guia.
Ross Debortoli
Membro desde: 10/17/25
325 Reputação
Autoria de 3 guias
Equipe
UMass Dartmouth, Team 2-6, Bowman Fall 2025 Membro de UMass Dartmouth, Team 2-6, Bowman Fall 2025
UMASSD-BOWMAN-F25S2G6
4 Membros
Autoria de 77 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 12
Últimos 30 dias: 58
Ao todo: 280
