Ir para o conteúdo principal
Game Boy Pocket LCD Screen Replacement
O que você precisa
  1. Game Boy Pocket LCD Screen Replacement, Remove the external screws: passo 1, imagem 1 %32 Game Boy Pocket LCD Screen Replacement, Remove the external screws: passo 1, imagem 2 %32 Game Boy Pocket LCD Screen Replacement, Remove the external screws: passo 1, imagem 3 %32
    • Place the Game Boy Pocket face-down on a clean, flat surface.
    • Remove batteries from battery compartment.
    • Use a Y1 tri-wing screwdriver and turn counterclockwise to remove the four external screws.
    • Use a Y1 tri-wing screwdriver and turn counterclockwise to remove the two screws inside the battery compartment.
    Pergunte ao FixBot
    Comentar
  2. Game Boy Pocket LCD Screen Replacement, Open the device: passo 2, imagem 1 %32 Game Boy Pocket LCD Screen Replacement, Open the device: passo 2, imagem 2 %32 Game Boy Pocket LCD Screen Replacement, Open the device: passo 2, imagem 3 %32
    • Place your hands on the front and back covers of the Game Boy Pocket, and carefully separate the device.
    • Set the back cover aside. You will need it to reassemble the device.
    Pergunte ao FixBot
    Comentar
  3. Game Boy Pocket LCD Screen Replacement, Remove the motherboard screws: passo 3, imagem 1 %32
    • Use a Phillips #1 screwdriver and turn counterclockwise to remove the three screws on the motherboard.
    Pergunte ao FixBot
    Comentar
  4. Game Boy Pocket LCD Screen Replacement, Remove the clip securing the ribbon cable: passo 4, imagem 1 %32 Game Boy Pocket LCD Screen Replacement, Remove the clip securing the ribbon cable: passo 4, imagem 2 %32 Game Boy Pocket LCD Screen Replacement, Remove the clip securing the ribbon cable: passo 4, imagem 3 %32
    • Use a plastic opening tool to dislodge and remove the clip securing the ribbon cable.
    • Make sure you apply pressure on both sides of the clip to loosen it.
    Pergunte ao FixBot
    Comentar
  5. Game Boy Pocket LCD Screen Replacement, Dislodge the ribbon cable: passo 5, imagem 1 %32 Game Boy Pocket LCD Screen Replacement, Dislodge the ribbon cable: passo 5, imagem 2 %32
    • Use a plastic opening tool to dislodge the ribbon cable.
    • Be gentle to prevent tearing the ribbon.
    Pergunte ao FixBot
    Comentar
  6. Game Boy Pocket LCD Screen Replacement, Remove the motherboard: passo 6, imagem 1 %32 Game Boy Pocket LCD Screen Replacement, Remove the motherboard: passo 6, imagem 2 %32 Game Boy Pocket LCD Screen Replacement, Remove the motherboard: passo 6, imagem 3 %32
    • Grab the black piece protruding from the motherboard, and lift up to remove the motherboard.
    • Set the motherboard aside. You will need it to reassemble the device.
    Pergunte ao FixBot
    Comentar
  7. Game Boy Pocket LCD Screen Replacement, Remove the LCD screen: passo 7, imagem 1 %32 Game Boy Pocket LCD Screen Replacement, Remove the LCD screen: passo 7, imagem 2 %32 Game Boy Pocket LCD Screen Replacement, Remove the LCD screen: passo 7, imagem 3 %32
    • Use a plastic opening tool to lift the LCD screen away from the front cover.
    • Use your fingers to remove the LCD screen.
    Pergunte ao FixBot
    Comentar
Conclusão
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
21 outras pessoas executaram este guia.
Adriana Rahrig
Membro desde: 10/07/14
1.688 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team 1-1, Leahy Fall 2014 Membro de USF Tampa, Team 1-1, Leahy Fall 2014
USFT-LEAHY-F14S1G1
4 Membros
Autoria de 24 guias
3Comentários do guia
please can anyone give me a website that sells replacemtn screens for the Gameboy pocket?
help please - Responder Compartilhar
There's no website that sells replacement screens the only way to get one is to order another Gameboy off of eBay and take out the screen
Isaac fraser - Responder Compartilhar
I get mine from Handheld Legend. They have all the Gameboy parts you could ever want.
Chris Pavlik - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 6
Últimos 7 dias: 70
Últimos 30 dias: 430
Ao todo: 34,915
