Ir para o conteúdo principal
Game Boy Micro Motherboard Replacement
O que você precisa
  1. Game Boy Micro Motherboard Replacement, Faceplate: passo 1, imagem 1 %32 Game Boy Micro Motherboard Replacement, Faceplate: passo 1, imagem 2 %32
    • Locate the two circular holes on the side of the Game Boy nearest to the directional pad.
    Pergunte ao FixBot
    Comentar
  2. Game Boy Micro Motherboard Replacement: passo 2, imagem 1 %32 Game Boy Micro Motherboard Replacement: passo 2, imagem 2 %32 Game Boy Micro Motherboard Replacement: passo 2, imagem 3 %32
    • Straighten the end of a paper clip and push it into each of the circular holes.
    • You may hear a faint click afterwards.
    • Use the paper clip to lever the faceplate off from the unit.
    Pergunte ao FixBot
    Comentar
  3. Game Boy Micro Motherboard Replacement, Remove the Cover: passo 3, imagem 1 %32 Game Boy Micro Motherboard Replacement, Remove the Cover: passo 3, imagem 2 %32
    • Remove the Phillips #00 screw on the side of the Game Boy closest to the directional pad.
    • Once the screw has been loosened, lift the cover off the back of the device.
    Pergunte ao FixBot
    Comentar
  4. Game Boy Micro Motherboard Replacement, Unscrew the Outer Cover: passo 4, imagem 1 %32 Game Boy Micro Motherboard Replacement, Unscrew the Outer Cover: passo 4, imagem 2 %32
    • Remove the two tri-wing screws on the top of the Game Boy and the two screws next to the volume/contrast switch.
    Pergunte ao FixBot
    Comentar
  5. Game Boy Micro Motherboard Replacement: passo 5, imagem 1 %32 Game Boy Micro Motherboard Replacement: passo 5, imagem 2 %32 Game Boy Micro Motherboard Replacement: passo 5, imagem 3 %32
    • Remove the three Phillips #00 screws.
    • Remove the two tri-wing screws.
    Pergunte ao FixBot
    Comentar
  6. Game Boy Micro Motherboard Replacement: passo 6, imagem 1 %32 Game Boy Micro Motherboard Replacement: passo 6, imagem 2 %32 Game Boy Micro Motherboard Replacement: passo 6, imagem 3 %32
    • Lift the back cover off of the Game Boy.
    Pergunte ao FixBot
    Comentar
  7. Game Boy Micro Motherboard Replacement: passo 7, imagem 1 %32 Game Boy Micro Motherboard Replacement: passo 7, imagem 2 %32 Game Boy Micro Motherboard Replacement: passo 7, imagem 3 %32
    • Remove the two Phillips #00 screws from the plastic frame.
    • As you are pulling off the plastic frame, the shoulder buttons and the volume switch may fall out of the device.
    • Underneath each shoulder button is a small spring. Do not lose them.
    Pergunte ao FixBot
    Comentar
  8. Game Boy Micro Motherboard Replacement: passo 8, imagem 1 %32 Game Boy Micro Motherboard Replacement: passo 8, imagem 2 %32
    • With a spudger, depress the small clip on the lower right corner of the plastic guard.
    • Grab the edges of the plastic frame and lift the frame off the motherboard.
    Pergunte ao FixBot
    Comentar
  9. Game Boy Micro Motherboard Replacement: passo 9, imagem 1 %32
    • Remove the two gold Phillips #00 screws from the motherboard.
    Pergunte ao FixBot
    Comentar
  10. Game Boy Micro Motherboard Replacement: passo 10, imagem 1 %32 Game Boy Micro Motherboard Replacement: passo 10, imagem 2 %32
    • With one hand, gently slide the top left end of the motherboard up and out of the front case.
    • With your other hand, pull out the EMI shield until the tab comes out of the front case.
    • Once the tab is pulled out from the bottom, slide the EMI shield down and out of the device.
    Pergunte ao FixBot
    Comentar
  11. Game Boy Micro Motherboard Replacement: passo 11, imagem 1 %32 Game Boy Micro Motherboard Replacement: passo 11, imagem 2 %32 Game Boy Micro Motherboard Replacement: passo 11, imagem 3 %32
    • The entire motherboard is now accessible.
    • Take extreme care when working with the motherboard to avoid damaging the device and its components.
    • A small ribbon cable connects the start and select buttons to the motherboard. It can rip very easily, so do not pull on it.
    • Lift the motherboard and the front plastic cover assembly off of the front case.
    • Once the front case is removed, the plastic on/off switch will fall out of place.
    Pergunte ao FixBot
    Comentar
  12. Game Boy Micro Motherboard Replacement: passo 12, imagem 1 %32 Game Boy Micro Motherboard Replacement: passo 12, imagem 2 %32 Game Boy Micro Motherboard Replacement: passo 12, imagem 3 %32
    Ferramenta utilizada neste passo:
    • When you remove the motherboard from the front case, the start and select buttons may fall out.
    • If the buttons do not fall out, remove them with a pair of tweezers.
    Pergunte ao FixBot
    Comentar
  13. Game Boy Micro Motherboard Replacement: passo 13, imagem 1 %32 Game Boy Micro Motherboard Replacement: passo 13, imagem 2 %32 Game Boy Micro Motherboard Replacement: passo 13, imagem 3 %32
    • Without the front case, you will be left with the motherboard and the plastic mount. The LCD screen is attached to the motherboard by a ribbon and can fall off the plastic mount.
    • Using metal tweezers, grab the start/select board and slide it out gently.
    Pergunte ao FixBot
    Comentar
  14. Game Boy Micro Motherboard Replacement: passo 14, imagem 1 %32 Game Boy Micro Motherboard Replacement: passo 14, imagem 2 %32
    • Lift the entire motherboard assembly off the plastic guard.
    • Take caution not to damage any of the gold ribbon cables on the motherboard.
    • The LCD screen is the only thing connecting the motherboard and plastic guard.
    Pergunte ao FixBot
    Comentar
  15. Game Boy Micro Motherboard Replacement: passo 15, imagem 1 %32 Game Boy Micro Motherboard Replacement: passo 15, imagem 2 %32
    • To remove the LCD screen, carefully angle it until it is diagonal to the square hole in the plastic guard and slide it out.
    • It is now possible to remove the entire motherboard assembly from the plastic guard.
    Pergunte ao FixBot
    Comentar
  16. Game Boy Micro Motherboard Replacement: passo 16, imagem 1 %32 Game Boy Micro Motherboard Replacement: passo 16, imagem 2 %32 Game Boy Micro Motherboard Replacement: passo 16, imagem 3 %32
    • On the plastic guard, there are two rubber pads that cover the buttons. Remove them.
    • These pads rest on the motherboard and sometimes stick to it. If they do, peel them off.
    • With the rubber pads off, you may use your fingers to remove the buttons to clean or replace them.
    • When returning the buttons to the guard, they have to be put back in exactly the way they were pulled out.
    Pergunte ao FixBot
    Comentar
  17. Game Boy Micro Motherboard Replacement, Motherboard: passo 17, imagem 1 %32 Game Boy Micro Motherboard Replacement, Motherboard: passo 17, imagem 2 %32 Game Boy Micro Motherboard Replacement, Motherboard: passo 17, imagem 3 %32
    • The LCD screen is connected to the motherboard by two ribbon cables.
    • Use a plastic spudger to disconnect the LCD's ZIF connector.
    Pergunte ao FixBot
    Comentar
  18. Game Boy Micro Motherboard Replacement: passo 18, imagem 1 %32 Game Boy Micro Motherboard Replacement: passo 18, imagem 2 %32 Game Boy Micro Motherboard Replacement: passo 18, imagem 3 %32
    • Use the tip of the spudger to lift the small, black tab holding the thin ribbon.
    • With both tabs lifted, pull the ribbons off the motherboard and remove the LCD screen.
    Pergunte ao FixBot
    Comentar
Conclusão
20 outras pessoas executaram este guia.
Equipe
Cal Poly, Team 8-46, Regan Winter 2010 Membro de Cal Poly, Team 8-46, Regan Winter 2010
CPSU-REGAN-W10S8G46
5 Membros
Autoria de 25 guias
1Comentário do guia
Ich wollte vorne das Cover wechseln bei dem gameboy micro und ich habe zu doll in die Löcher reingestochen so das es in drinnen gebrochen ist... Wer kann das reparieren?? Hilfe
Prisoner Jimmy - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 51
Últimos 30 dias: 238
Ao todo: 31,556
