Introdução
This guide will show how to safely replace the battery without damaging other parts of the board, or the battery itself.
O que você precisa
Remove the Phillips #00 screw on the side of the Game Boy closest to the directional pad.
Once the screw has been loosened, lift the cover off the back of the device.
Grip, and gently pull outwards on the cable as close to the battery connector as you can
Uma outra pessoa concluiu este guia.
