Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Locate the battery compartment on the back of the Game Boy Color.
Push down on the tab and hinge the cover downwards and outwards to remove the battery cover.
Using a Y1 screwdriver, remove the six screws on the back of the device as pictured. The bottom two screws are located inside of the battery compartment.
Gently lift and separate the back housing from the rest of the device. Now you've got the back housing out!
Using the Phillips #1 screwdriver, remove the 3 screws shown in the picture.
Gently lift the motherboard from the front housing.
Unsolder and remove the LED from the circuit board.
Insert new LED into the circuit board.
The positive lead should go through the hole closest to the edge of the circuit board.
Solder the leads of the new LED to the circuit board.
Cut the excess ends of the LED legs using the wire cutters.
7 outras pessoas executaram este guia.
6 comentários
what is the brass color looking thing under the soldering iron in step 7?
That's called 'Desoldering Braid', it sucks up solder like a wick
and what kind of LED are you using to replace?
Bw sure to research what LED colors work best. You often need to remove a resistor adjacent to the diode to allow for the colors white/blue/purple.
