Ir para o conteúdo principal
Game Boy Color Power LED Replacement
O que você precisa
  1. Game Boy Color Power LED Replacement, Battery: passo 1, imagem 1 %32 Game Boy Color Power LED Replacement, Battery: passo 1, imagem 2 %32
    • Locate the battery compartment on the back of the Game Boy Color.
    • Push down on the tab and hinge the cover downwards and outwards to remove the battery cover.
  2. Game Boy Color Power LED Replacement: passo 2, imagem 1 %32
    • Remove the batteries from the battery compartment.
  3. Game Boy Color Power LED Replacement, Back Housing: passo 3, imagem 1 %32
    • Using a Y1 screwdriver, remove the six screws on the back of the device as pictured. The bottom two screws are located inside of the battery compartment.
  4. Game Boy Color Power LED Replacement: passo 4, imagem 1 %32 Game Boy Color Power LED Replacement: passo 4, imagem 2 %32
    • Gently lift and separate the back housing from the rest of the device. Now you've got the back housing out!
  5. Game Boy Color Power LED Replacement, Motherboard: passo 5, imagem 1 %32 Game Boy Color Power LED Replacement, Motherboard: passo 5, imagem 2 %32
    • Using the Phillips #1 screwdriver, remove the 3 screws shown in the picture.
  6. Game Boy Color Power LED Replacement: passo 6, imagem 1 %32
    • Gently lift the motherboard from the front housing.
  7. Game Boy Color Power LED Replacement, Power LED: passo 7, imagem 1 %32 Game Boy Color Power LED Replacement, Power LED: passo 7, imagem 2 %32
  8. Game Boy Color Power LED Replacement: passo 8, imagem 1 %32
    • Insert new LED into the circuit board.
    • Make sure that the LED is in the correct orientation. The longer leg of the LED is the positive end, while the shorter leg is the negative end.
    • The positive lead should go through the hole closest to the edge of the circuit board.
  9. Game Boy Color Power LED Replacement: passo 9, imagem 1 %32
    • Solder the leads of the new LED to the circuit board.
  10. Game Boy Color Power LED Replacement: passo 10, imagem 1 %32
    • Cut the excess ends of the LED legs using the wire cutters.
Conclusão
8 outras pessoas executaram este guia.
Alex Wu
Membro desde: 01/11/13
1.658 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 19-47, Regan Winter 2013 Membro de Cal Poly, Team 19-47, Regan Winter 2013
CPSU-REGAN-W13S19G47
4 Membros
Autoria de 61 guias
6Comentários do guia
what is the brass color looking thing under the soldering iron in step 7?
Soul Divide - Responder
That's called 'Desoldering Braid', it sucks up solder like a wick
John Smith -
and what kind of LED are you using to replace?
This was great! Exactly what I needed with this. My GBC is looking good as new now!
Erick - Responder
Bw sure to research what LED colors work best. You often need to remove a resistor adjacent to the diode to allow for the colors white/blue/purple.
Evan Wilgosh - Responder
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 19
Últimos 30 dias: 123
Ao todo: 20,231
