Introdução
Use this guide for disassembly and for resolving jammed or finicky shoulder buttons.
Ferramentas
Peças
Nenhum componente especificado.
Take the battery cover off by releasing the locking tab and hinging the cover away.
Remove bottom back panel screw with a Phillips #1 screw driver.
We recommend you change the the screw head to a Phillips 1 so you don't strip the screw. (Something we experienced)
Remove left and right triggers by lifting and pulling them away from the system.
Do the same for side panels
3 outras pessoas concluíram este guia.
