Ir para o conteúdo principal
GPD Win Battery Replacement
O que você precisa
  1. GPD Win Battery Replacement, Battery: passo 1, imagem 1 %32
    • Shut down your GPD Win.
    Pergunte ao FixBot
    Comentar
  2. GPD Win Battery Replacement: passo 2, imagem 1 %32
    • Remove SD card and duct cover.
    Pergunte ao FixBot
    Comentar
  3. GPD Win Battery Replacement: passo 3, imagem 1 %32
    • Remove the six PH #00 screws on the back of the GPD.
    Pergunte ao FixBot
    Comentar
  4. GPD Win Battery Replacement: passo 4, imagem 1 %32 GPD Win Battery Replacement: passo 4, imagem 2 %32 GPD Win Battery Replacement: passo 4, imagem 3 %32
    • Carefully insert the pry tool between the keyboard and case.
    • Move the tool around the edge until every clip is released.
    • Carefully lift the back half of the case.
    • You'll see a small ribbon connector on the right. Use your pry tool to remove it by lifting up.
    • On the right, you'll see another white connector going to the battery. Use the pry tool and pull back on the connector to release it.
    Pergunte ao FixBot
    Comentar
  5. GPD Win Battery Replacement: passo 5, imagem 1 %32 GPD Win Battery Replacement: passo 5, imagem 2 %32 GPD Win Battery Replacement: passo 5, imagem 3 %32
    • Separate the two halves of the device.
    • Use the pry tool and slowly and carefully separate the adhesive from the back of the case.
    • Remove old battery.
    Pergunte ao FixBot
    Comentar
  6. GPD Win Battery Replacement: passo 6, imagem 1 %32 GPD Win Battery Replacement: passo 6, imagem 2 %32
    • Use two to three strips of the double sided tape and apply it to the back of the battery.
    • Line up the battery with the lines on the case and the connector on the right.
    Pergunte ao FixBot
    Comentar
Conclusão
3 outras pessoas executaram este guia.
1Comentário do guia
At the moment, the Shenzhen Zero Five Battery Company replacement comes with two wires crossed. You'll need a small metal pick to pry the clips open enough to pull the conductors out and swap them over. It should be red, yellow, black. I've performed the modification and can confirm it works after switching the contacts.
Dr. Nick - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 8
Últimos 7 dias: 35
Últimos 30 dias: 122
Ao todo: 7,907
