Ir para o conteúdo principal
GE Washing Machine Agitator Replacement
Guia de vídeo
Este guia foi transcrito de um vídeo do YouTube.
O que você precisa
    • Raise the lid to give full access to the agitator assembly.
    Pergunte ao FixBot
    Comentar
    • Look for the small round hole located at the very bottom of the agitator skirt.
    • This hole is the only place where a tool can lock the agitator for removal.
    Pergunte ao FixBot
    Comentar
    • Feel around the agitator base until you find the raised nipple on the washer plate.
    • Rotate the agitator until its hole lines up directly over the nipple.
    • Removal will not work unless these two features line up exactly.
    Pergunte ao FixBot
    Comentar
    • Insert a Phillips screwdriver through the hole and press it in until it bottoms out.
    • Push the screwdriver in deeply so it fully engages the mechanism.
    Pergunte ao FixBot
    Comentar
    • Have a helper hold the washer tub steady so it cannot rotate while you twist the agitator.
    • If working solo, brace the tub with your free hand while keeping the screwdriver seated.
    Pergunte ao FixBot
    Comentar
    • Grip the agitator housing and turn it clockwise until it breaks free from the drive tabs.
    • Lift the agitator straight up and out of the tub once it releases.
    Pergunte ao FixBot
    Comentar
    • If you need hub access, remove the central 7⁄16-inch bolt with a socket wrench and lift off the plate.
    Pergunte ao FixBot
    Comentar
    • Align the four slots on the agitator base with the four plastic retention pieces on the washer plate.
    • Lower the agitator onto the tabs until it sits flush on the plate.
    Pergunte ao FixBot
    Comentar
    • Twist the agitator clockwise until it snaps and will not rotate freely.
    • Rock the agitator back and forth to confirm it is fully seated.
    Pergunte ao FixBot
    Comentar
    • Press the fabric-softener dispenser cap back onto the agitator top.
    Pergunte ao FixBot
    Comentar
Conclusão
Repair didn't go as planned? Ask our Answers community for help.
Ben Schlichter
Membro desde: 01/21/25
7.100 Reputação
Autoria de 224 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 6
Últimos 7 dias: 56
Últimos 30 dias: 219
Ao todo: 901
